20 Most Recent
Roadmaster (VR500CSBT) Questions & Answers
After installing the unit the face will not light up or come on the two buttons over and under the volume button will light up
Double check the red..yellow and ground wires..sounds like your not getting power.. check fuse in unit itself.. when installing any component in a vehicle..triple check and use things like solder and shrink wrap..always remove negative cable from vehicle battery prior to starting work or adjustments .also prior to removing cable from battery..reference owners manual.. some vehicles need to be disconnected a certain way to avoid future electrical and drivability problems..also ensure faceplate is secure
I need instructions in english
Follow the link below and you should see a download link of the manual from the page.
http://caraudio.manualsonline.com/manuals/mfg/roadmaster_usa/vr500cs-bt.html
Hope this was helpful?
How do i reset the pin number
This is NOT anything to do with the iPhone. What is required is the SECURITY CODE for that radio, this is an anti-theft system. You need to contact the maker, and they will give you a number, after proving it is legally yours.
I'm connecting this to my
Connect the wires according to the diagram provided with the 1998 ford f150. But on truck side you need to identify the speaker wire and power wire to connect.
Revert back for more assistance.
No sound everything works fine.
If you are sure that everything is hooked up correct and have no sound, you most likely have a bad speaker that caused the final amplifier to go out. These are two chips mounted inside the radio towards the rear. they are connected to a large heat-sink to distribute heat. If your savy enough you can replace them yourself, otherwise you will need to take it to a shop. This is a comon problem and not a very expensive fix. Before replacing the deck back in the vehicle, be sure your speakers are checked and read at least 4 ohms each.
NO SOUND AFTER INSTALLING VRCD400-SDU
I had the same problem and all I did was buy new wires the ones that came with the stereo itself burned up and seased to work. now I paid $6.00 for it at best buy. they look the same colored wires as the ones that came in it.
Installing VR500CS-BT
Yes. You can install ANY stereo with just two speakers. Just make sure you have the other two output wires taped off real good.
