20 Most Recent
Stanton T.120 Turntable Questions & Answers
Platter wont spin on stanton
The belt that drives the platter may have shifter or the gears that turn the platter may be unaligned. Open it up yourself and check out the inside but be careful not to break anything or go into a local music/dj store. they may be able to help you for cheap or for free.
Half the signal only through left speaker
Try the switch in the other position and see if that fixes the problem. some turntables had a phono level that is different than a standard rca line level input. Also try a different cable if the rca is not hardwired in to the turntable. The cable could be bad. If worse comes to worse upgrade to another amplifier or tuner that has a separate phono input. hope that helps.
Where can i find replacement pitch fader for
Google "The Needle Doctor" - and then call them. I was just in their shop, and they have Tons of spare parts. (and an aquarium full of disposed cartridges/needles - pretty funny!)
How do i fix my turntable when the output is
First - Has the cartridge failed, or has a wire become lose to it? Have you checked the cable comming from deck?
If you have or none of these gives solves the problem, then try reversing the leads on the cartridge so the good ouput gets the missing channel. If you still can't hear it then there's a electronic fault on the left hand channel pre-amp inside the record deck.
Distortion
you shoudnt run your turntable through line m8 just phono use line for cd decks
My Stanton STR8-60 is not tuned correctly. I need help trying to get it to hold the right rpm for the platter.
You know it isn't for playing records. It is made for DJ Scratching from the 1980s.
Str8-60, any facts of info?
Vinyl Engine
https://www.vinylengine.com > viewtopic
Feb 18, 2012 - The s
tr8-60 is the bottom of the line dl deck from stanton, and has straight tonearm. it is
designed for dj use and is not really suitable for ...
AT150MLX on Stanton STR8-60? - Vinyl Engine
May 25, 2016
Ground wire repair on Stanton STR8-60 - Vinyl Engine
May 5, 2021
Stanton STR8-60 Replacement Power Cable - Vinyl Engine
1 post
Apr 18, 2021
Picking a cartridge with a turntable with no anti-skating
Mar 31, 2015
More results from www.vinylengine.com
stanton str8-60 : r/turntables
Reddit · r/turntables
2 comments · 9 months ago
The
STR8 turntables have a totally straight tonearm designed for DJ "scratching". If you just want to listen to records, they're not good ...
$50 Stanton STR8-60 got picked up today; all it needed was a ...
May 20, 2021
Stanton STR8 any good? : r/vinyl - Reddit
Oct 29, 2015
Stanton turntable model str8-50 vs. AT LP-60? - Reddit
Nov 13, 2023
Two Stanton T.60's and a M.202 mixer for $150? : r/DJs - Reddit
Jan 11, 2019
More results from www.reddit.com
How do i replace burnt fuses on stanton t62 m2 turntables
If they are the glass type fuses then they might still have the wattage on the metal ends.
However that might be the least of your problems. Fuses blow like that due to an overload. So you should look around for a shorted device such as a power transistor or anything having an heat sink on it.
