20 Most Recent
Whirlpool 21.8 cu. ft. Side-By-Side Refrigerator with PuR Filtered Ice and Water Questions & Answers
I replaced the water filter
1.CAN YOU TELL IF WATER IS GOING TO THE FILTER, FIRST OF ALL.
2.IF WATER IS NOT GOING THREW THEN THERE IS A BLOCKAGE BEFOR THE FILTER
3. IF WATER IS GOING TO THE FILTER { CHECK TO IF THE FILTER IS IN CORRECTLY}
4.IS THE WATER GOING THREW THE FILTER, IF SO THERE IS A PROBLEM WITH THE KINE FROM THE FILTER TO THE LEVER TOR THE WATER TO COME OUT.
5. ALSO CHECK FOR LEAKS GOOD LUCK
Inside back of freezer making a loud noise
Hello the fault is most likely to be the defrost system building up frost around the fan and causing the bad sound to prove this just turn off freezer for about 10 hours to defrost and restart if noise has gone away then your defrost system is faulty
Where is the filter for
Removing and replacing a water filter - base grill
location
Filters situated in the base grill (below the freezer compartment) of
Whirlpool-built side-by-side refrigerators are relatively simple to replace.
Follow these two steps:
- Grasp the filter's end and make a one-quarter turn to the left.
- Pull the filter straight out.
To replace with a new filter, repeat these two steps in the opposite order,
making sure to first remove the red cap from the filter. Proceed by pushing the
filter straight into the slot, and then giving it a one quarter turn to the
right.
Note: Replacing this type of filter is quick - there is no need to
unplug your refrigerator when replacing it. Also, this filter should be replaced
every six months.
My Whirlpool ice maker suddenly stopped making
look behinnd ur refrigerator u will see a blue solenoid valve with e wires on it take the wire off of it and put ur meter leads in the wires and see if u r getting any power to the wires leave the m,eter leads in and try rotating the ice arm around by hand and see if u get any power as u do this if u do then put the wires back on and see if u can feel the solenoid open up when u rotate it if it opens and water starts coming out then u may have had the arm on the ice maker stuck now that uve got it unstuck it may work ok now but if u never get any power to the solenoid then u probably need to replace the ice maker hope this helps
Water filter replacement?
You do have a filter on the bottom kick plate. It looks like a round cap and it's the same color as your refrigerator. Give us a call and we'll be happy to send the correct filter out to you. Hope this helps and we look forward to hearing from you soon.
Stomach pain drinking from refrigerator water dispenser
Get a charcoal filter from home depot (about 50.00) and install behind refrig or in cabinet . Filter has replaceable cartridges like for charcoal , lime , calcium . Installs in supply line to refridg . Do not recommend the 11.00 filter installed in line , where you replace the whole filter . Get the replaceable cartridge type .
Ice maker
filter its on the kick plate @ the bottom of the freezer door,push the side button and the filter unlocks
