20 Most Recent M-Audio Delta 1010LT Sound Sound Card Questions & Answers
Your first line stated the obvious; the PC can run 2 cards, but the G4 cannot. The Mac, although a 'PC' has significant hardware differences with an IBM derrved PC.
M-Audio Delta... | Answered on Feb 25, 2015
Try using nLite to slipstream the drivers into your xp installation. Tutorial can be found Here.
M-Audio Delta... | Answered on Jan 28, 2015
You need to clear your driver and then refresh your windows 7 updates.It will fix
M-Audio Delta... | Answered on Mar 04, 2011
what is your problem?if i can i will help you
M-Audio Delta... | Answered on Feb 19, 2011
You can download the drivers for your modelGateway laptop from this WEB site, make sure you select your model laptop andthe correct XP or Vista drivers. Click on this link to download the drivers: -
http://driver-pro.com/related/english/hardware-drivers/?a=12221&gclid=COmm19XHtpwCFSMSagodPRuwnQ&hit=1
M-Audio Delta... | Answered on Feb 13, 2011
yes
M-Audio Delta... | Answered on Aug 24, 2009
Hi, Your driver CD does not have the drivers for Windows Vista on it. You need to download the driver from the internet. Below is a link for Vista (as long as you're running the 32-bit version). You can click on it or cut and paste it into your browser address bar. Click on the fastest response speed underlined link on that page to download (and remember where you download it to on your computer.) Click on the file and it should install the driver for you. Hope this helps! Hal
http://www.driversdown.com/ViewDownloadUrl.asp?ID=98906&brNum=3&show=0
M-Audio Delta... | Answered on Jun 06, 2009
go to control panel and here open sound and supoort icon.... chk it is performing well.....if it is not wrking then may be reinstall the driver of sound driver and then play the audio
M-Audio Delta... | Answered on Mar 23, 2009
i cannot uninstall or upgrading my audio drivers to my note book compaq prasario c700
M-Audio Delta... | Answered on Mar 11, 2009
I don't believe that is going to work, the reason being the operating system will only accept one input device recording at a time...meaning you cannot record with 2 cards simultaneously....the only way you MAY be able to pull this off is if you record with 2 separate programs , and make each program use a different input device....
M-Audio Delta... | Answered on Feb 16, 2009
go to http://www.m-audio.com/index.php?do=support&tab=driver and select "drivers and software" from top of page
M-Audio Delta... | Answered on Nov 30, 2008
To answer your question I would go to the M-audio desktop icon and double click on it to open it up. Go to monitor and make shure that you bring the levels of each one of the tracks up to 2/3 rd up. Pan each one hard left and hard right and make shure mute is off. Click the top boxes at the bottom of the vu slot and see if that helps. Also you must save it or it will return to the previous settings.
M-Audio Delta... | Answered on Aug 15, 2008
Well I guess my problem is a little less important. I have 1-2 3-4 5-? 7-8. I dont know where 6 went. I even checked to see if I could plug a wire into the input and toutch it with my finger to see if I got a vu response, Nothing.
Do you have 5.1 speakers? Becouse you need to plug in all the 5.1 speakers to the differnt ports on your soundcard. If you only have 2 speakers you wont be able to get the 5.1 surrond sound your after and it will default to 2 speakers. If you do have 5.1 speakers then you will need to check the option in the control panel in the M-Audio window. It has an option for 5.1 surround. If your software cannot play 5.1 surround them get some other software that can.
M-Audio Delta... | Answered on Aug 01, 2008
M-Audio Delta 1010LT Sound Sound Card Logo
Popular Tags
33 questions posted
Top M-Audio Computers & Internet Experts
Edward Easley
Edward Easley
John Bolton
Thomas F. Schneider
Are you a M-Audio Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • M-Audio Computers & Internet
Most Popular Question
more audio driver installer gateway
  • Computers & Internet
