20 Most Recent
Homedics Sound Spa Premier SS-5000 Clock Radio Questions & Answers
Remote Sensor
make sure your time is set and the atomic clock time is recieved, then leaving the rear cover off of the transmitter, push the "tx" button not the "c/f" that is just for centegrade or ferenhight. you will see the red light on the front of reciever flash in a few seconds. The temp should display on your clock screen. If not, did the red l.e.d. light on transmitter flash. If not, its not sending data to clock. I have to reset and hit transmit every time I replace batteries on transmitter. Had no problems for over 2 years of using outside. If your not getting a reading with transmitter sitting next to clock after hitting "tx" button you may have defective transmitter.
Set the alarm
Hold down Alarm Set for about 5 seconds until the time flashes, then just press the hour and minute buttons until the time you want is shown. Remember that the pm light WILL come on if you need the alarm set for the evening.
