20 Most Recent
KitchenAid KGRS807SSS Gas Kitchen Range Questions & Answers
When I turn the oven on, there is a fan that comes
yes this will work for you, but before you change out the fan motor make certain the fan blades are unobstructed and not rubbing against anything this can make quite a horrible noise as well.best regards Falco
One burner won't light have gas and spark. Cap
Hello
Burners will not light if there is the smallest amount of water in the holes. Have you washed the stove top recently?clean your stove, turn gas on high, light it with a lighter, and wait about an hour.....its normaly just a bit wet in there doing this lets it dry out.
blow air from your mouth at it as you are clicking it to light or use a match or try cleaning the electronic ignighter off.sometimes they get dirty and wont work
you can usually take the burner out and give it a good clean, make sure none of the holes are blocked with food etc, if its the ignition switch try using a lighter or matches to turn it on,
If these do not work then i suggest you replace the burner but this might be a bt expensive
We have a Kitchenaid gas
Check your circuit breakers and or ground fault circuit interrupters.GFI.
You have no power to the range.
Used self cleaning feature &
I am sorry to hear regarding the trouble.
Be advised that as i am not there, i cannot provide legitimate 2nd opinion.However,i would be glad to add few inputs to the diagnosis.
This error message indicates - Oven temperature is too high (Clean mode)
Solution - Replace oven temperature sensor
It is located in the upper corner inside the oven.You need to test it
for resistance it should have a reading of about 1100 ohms.
If the resistance is wrong, you need to replace it.
Do not forget to ' ACCEPT ' the solution, so that i could get the credit for my time.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Im having a problem with getting my oven to
Hello and sorry to hear about your problem.
It sounds like your oven glow rod, is defective. This is the electronic pilot lite for the unit.
I suggest you can in a service person. If you live in the Denver Co area, I can help you.
I have tried to help you. Please help me by Vote/Rate this response. Thanks and good luck.
cvbb
cvbcb
