20 Most Recent ACE Hardware HFH426-U Heater Questions & Answers
Dawlance 1 ton A/C after 3 months may A/C dims the electricity for compressor, and and not cooling. The compressor is not running and doesn't drip the water.
question edited for clarity. Air conditioning will often dim the power a bit as the compressor draws a lot of power. It may be that your Start Capacitor has failed and this is why you are noticing it, plus the fact you don't hear the compressor running. The water doesn't drip because there is no frost and no condensate. You need a refrigeration guy. It is quick to diagnose and they keep start capacitors in the van. Call out plus 30 minutes.
8/7/2021 1:29:24 PM • ACE Heating &... • Answered on Aug 07, 2021
Dimplex obsidian
Sad... The bulbs called for (60W) do get VERY hot... (but the owners manual I found indicate a 60W USA style lamp... (appeared to be a E16 (Edison)). Euro lamps have higher voltage (and FRANKLY speaking) better heat tolerance... If you are terribly in love with this unit.. I would first suggest calling the "SUPPORT" to see if their "ENGINEERING" already has a solution... ELSE you should be looking for a couple CERAMIC (like glazed porcelain) sockets and prepare to FIELD ENGINEER a proper/safe remedy... My best suggestion... Call support Dimplex Obsidian OBS20 User Manual Page 9 Then contact your favorite hardware... (or LAMPS +) and ASK the MOST COMMON clear candelabra bulb socket That sports a CERAMIC type socket... E12 or E14 ... When I was "converting" a Spanish chandelier.. I used GLAZED Porcelain "EDISON twelves" (E12). > Keyless Porcelain Adjustable Candelabra Candle Socket eBay FINELED E12 Mini Candelabra Screw ceramic lampholder socket with 10 inch... AMAZON Sunlite 60CFC 32 12PK Candelabra E12 Base Flame Tip 60W Incandescent... Hope this helps Carnac the Magnificent
9/11/2017 4:34:38 PM • ACE Heating &... • Answered on Sep 11, 2017
How do I override a nonfunctioning remote for my Valor gas fireplace?
shut off the gas valve, and then call a qualified technician
12/18/2014 12:11:03 AM • ACE Heating &... • Answered on Dec 18, 2014
0answers
0answers
0answers
0answers
WE HAVE A FEDDERS AZ7A09W2A Through the Wall Room Air Conditioner. IT WILL NOT TURN OFF. PULLING THE POWER CORD IS THE ONLY WAY. DOES ANYONE KNOW THE CAUSE AND OR REPLACEMENT PART?
Question edited for clarity, full 'make model (what it is)'. Email address removed. You don't need the site's 12 million annual viewers emailing you to say they can fix it for a thousand bucks! Finally, Please don't type in all CAPS, it is considered SHOUTING and is harder to read. Repair Clinic has some good ideas, but your model is discontinued
Fedders Air conditioner won't turn off
Repair Clinic https://www.repairclinic.com > RepairHelp > Fedders-Ai... Here are the most common reasons your Fedders AC compressor won't turn off - and the parts & instructions to fix the problem yourself.
Why Your Air Conditioner Isn't Shutting Off, and How to Fix It
Williams Comfort Air https://williamscomfortair.com > ac-wont-shut-off When your air conditioner won't shut off, it's natural to worry about wasting electrical power as temperatures become too cool for comfort. ..
4/24/2024 1:44:56 AM • Heating &... • Answered Yesterday
2answers
I have a Bonair evap aircon model VSL75 with the comfort controller and I want to reduce the water dumping cycle down. I have tried the manual but that sequence didn't work.
Here are the steps you might want to follow: Setting the Draining Cycle Times (Dump Interval): This setting controls how often the unit dumps the water. You can adjust this setting to reduce the frequency of water dumping. Setting the Drain off Delay Time (Dump Delay): This setting controls the delay time before the unit starts to dump the water after it has been turned off. If adjusting these settings doesn't work, there could be other issues with your unit. For example, a continuous water dumping problem could be due to a faulty dump valve or a problem with the float valve.
4/21/2024 11:19:53 PM • Heating &... • Answered 3 days ago
What is E3 in frego split ac
Frego split ac error code h3 what is problem
4/16/2024 4:25:39 AM • Heating &... • Answered on Apr 16, 2024
2answers
What does E2 code mean on electric infrared heater
Model 2320cpb. E2 code
4/13/2024 11:00:34 AM • Heating &... • Answered on Apr 13, 2024
HP error code in bluestar split ac
Blue star inverter Ac HP error shown on display
4/10/2024 7:14:47 AM • Heating &... • Answered on Apr 10, 2024
2answers
Hello How can I disassemble my
Why do you need to dismantle this? Some of these types of cooler do not have replaceable parts inside. They are usually classed as a "Throw away" machine. It is often easier and cheaper to replace it than repair it.
4/9/2024 1:31:04 PM • Heating &... • Answered on Apr 09, 2024
My azure split ac see the error code df sir pls give me solution for df error
Azure 1.5 ton splits ac old model e2 error
4/9/2024 12:44:23 AM • Heating &... • Answered on Apr 09, 2024
My Goldair gas heater ignites but the centre burner does not glow or come on. What could be the problem?
Blocked jets clogged with dust or dirt, blocked injector need a clean / service
4/8/2024 8:36:41 PM • Heating &... • Answered on Apr 08, 2024
ACE Hardware HFH426-U Heater Logo
Popular Tags
1 questions posted
Top ACE Heating & Cooling Experts
Mike Cairns
Mike Cairns
ADMIN Andrew
ADMIN Andrew
deton8 von Splosion
Are you an ACE Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • ACE Heating & Cooling
Most Popular Question
any kinds problems air conditioner
  • Heating & Cooling
