20 Most Recent
Honeywell (CT62B1015) Baseboard Heater Questions & Answers
Baseboard heater
Make sure BOTH fuses on each heater circuit test ok -- they are no doubt 220V -- hence 2 fuses
11/8/2013 2:58:01 AM •
Honeywell...
Answered
on Nov 08, 2013
How do I know which
get what i call an idiot stick (it makes us not turn into idiots by us not getting shocked) fluke is the one I use this will detect even the faintest electrical field on electrical wires use this to detect the power in the wires.
3/4/2011 10:44:00 PM •
Honeywell...
Answered
on Mar 04, 2011
My heater won't shut off. The thermostat is off
Turn the circuit breaker (in your home's circuit breaker panel) that feeds that heater OFF. After the heater cools, remove the cover and check to see if the Thermostat wires have come loose. It may also be an electrical relay problem or the wall thermostat has gone bad.
2/18/2011 10:15:09 PM •
Honeywell...
Answered
on Feb 18, 2011
I have a Weil-McLain hot
Hello.Prob#1 valve has a bad END SWITCH,change the power head,thad brings the circ on when open.Prob#2 try manual overide lever.iS IT TIGHT OR SMOOTH?DOES IT JUMP/SNAP?motor very hot? all bad signs.Change that power head too.The transformers are OK because 1 trans can only run 3 valves max.
9/21/2010 1:59:21 PM •
Honeywell...
Answered
on Sep 21, 2010
Need to replace 2 wire baseboard thermostat
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
3/15/2010 9:24:58 PM •
Honeywell...
Answered
on Mar 15, 2010
Re-programming of Honeywell Chronothan III heating/cooling
Go to honeywell.com
3/15/2010 9:23:33 PM •
Honeywell...
Answered
on Mar 15, 2010
THERMOSTAT,P/N CT62B1015,NEED INSTALL INSTRUCTIONS
HONEYWELL WEBSITE:
Go to honeywell.com
3/15/2010 9:22:46 PM •
Honeywell...
Answered
on Mar 15, 2010
I CANT SEEM TO PROGRAM THE UNIT. IT SAYS IT SET AT
Go to honeywell.com
3/15/2010 9:21:40 PM •
Honeywell...
Answered
on Mar 15, 2010
How to install thermostat
HONEYWELL WEBSITE:
Go to honeywell.com
3/15/2010 9:20:58 PM •
Honeywell...
Answered
on Mar 15, 2010
Setting thermostat on Model HZ519
Go to honeywell.com
3/15/2010 9:18:06 PM •
Honeywell...
Answered
on Mar 15, 2010
Installed a Honeywell Thermostat - Heat will only
Go to honeywell.com
3/15/2010 9:13:00 PM •
Honeywell...
Answered
on Mar 15, 2010
