20 Most Recent
Remington Model 700 BDL LSS Bolt Action Rifle 5935, 300 Winchester Mag Questions & Answers
B6253254
Not unless you registered it. That would not be a smart thing to do.
What is the manufacture date
Look for the date codes on the left rear section of the barrel. It will be two letters. One is the month and the other is the year.
Old Remington 12 Ga. Auto Loader on Browning Frame. Serial No. 238817. Year Made.
are you talking about the old Model 11 which is a copy of Browning A-5? more details would help. But it probably has a solid rib (amazingly, those were machined in one piece with the barrel, not soldered on). Many have had barrel problems. Look closely at yours, especially for pitting in the bore and bulging at muzzle.
The model 11 remington shotgun was produced from 1905-1949 when it was changed to the 11-48 dating your shotgun to exact year MAY be possible if theres a date code on the barrel left side ,,this would proably be a 2 letter code.. and should be near the point where the barrel meets the receiver. Without it it's anybody's guess.
condition means the most for values but you can pickem up for a average between 200-350. for insurance purposes 400 if in good working order.
Model 11?
Sighting my rifle scope
Mount scope on rifle with the eye relief you are happy with
set up a target at 10 yards and fire 5 rounds of until you are grouping tightly ( no fliers ) you may want to use quite a few targets once you are happy with the grouping remove the adjustment covers on the scope
the top one is for moving the point of impact up or down
the side one is for left or right
depending on the point of impact you need to move it up or down to meet the cross hare once you get the point of impact on the same hight line as the aim point you can move the side adjuster to move the poi to meet the aim point
then move the target out to 20 yards and repeat the above again
then move the target out to a distance that you can put 90% of your shots inside 40mm or better and that is your max range for live animals
