20 Most Recent
Trendware 54Mbps 802.11g Wireless AP Questions & Answers
Can't connect to AT&T VPN
I'll need to know what router you're using, make and model, for more specific help, but sometimes there is an option for IPSec passthrough. For example, on my Linksys Wireless Router WRT54G, there is a set of buttons under Security/VPN that are entitled IPSec Passthrough, PPTP Passthrough, and L2TP Passthrough. Since I don't know what router you're using, I can't tell you wether or not your router supports such functions or not, but if it does, you need to enable them.
Cant connect to the AP menu TEW-430APB
clear your browser cache, close, relaunch your browser and try again
You probably cant access it because you are not authorized. If its locked on your rooftop then your ISP should configure your access and that you're not authorized.
Trendnet 430APB 54Mbps 802.11 AP
if you press the reset button at the back holding it in for about 10 seconds, that should set it back to it's default. Then in your address bar log back into it. The default username is usually admin and sometimes the password is admin too. If not it's either password or there is no password so you can just press enter on your keyboard. This way you can set it up the way you want to. Just be aware that if you use WEP 128 bit, you have to have 26 characters as a password. If you use WPA PSK then you only need 8 characters. You should be able to access this from the word wireless in your options list. I would run the setup again first and then do all the configuration next. Lets hope this helps you out.
My airport extreme
Its Because If There Is other computers or another interference it blocks and enables and disables the conduct given off for your wireless router I sugest try repositioning a little sometimes also if you are to close to the access point it will also have slight delays and issues! or you may try deleteing and reinstalling the instalation cd I hope this helps!
I have been trying to
You didn't state what kind of router that you are using with this wireless adapter. Your adapter is 150mbps so we know it is N technology.
It sounds like it is a security issue. I would suggest making sure that your security is matched perfectly being WEP, WPA, etc etc. If you are manually typing you broadcast ID into the setup for the adapter, it could be the spelling or punctuation. I have seen many people (including myself) have issues from leaving out 1 capital letter.
Having traded out the adapter for a new one you have eliminated that from consideration.
6/17/2011 4:37:22 AM •
Trendware...
Answered
on Jun 17, 2011
Trendnet 633-GR won't connect to the internet
Well I think that the internet is down from your ISP side
Did you try to call the internet service provider ? Your ISP must be DSL .
with the message " ue Mar 09 13:06:51 2004 PPP network down [INFO] Tue Mar 09 13:06:51 2004 WAN interface is down [INFO] "
It seems that the internet is down on the modem.
Click Here for more info about networking
4/3/2011 12:40:07 PM •
Trendware...
Answered
on Apr 03, 2011
