20 Most Recent Symbol AP-5131 Questions & Answers
2answers
How do i connect my symbol ap-5131 to my computer?
exist 2 ways to do it...
first if you now te ip address and the user and password of admin, conect the ap at the ethernet port of you pc and configure it with a ip in the same range that the ap, put the ip direcction in the web browser.
the second way is conect the ap to the serial port and run the hyperterminal if you have windows, maybe you need configure the values of the conecctions.
7/17/2013 11:48:51 AM • Symbol AP-5131 • Answered on Jul 17, 2013
This AP is in network
Ideally, there shouldn't be any configuration needed. Access points are transparent and only work as a bridge between wireless and wired network so devices should obtain their IP info from your DHCP server not the access point by default.If you face problems, then there might be a DHCP server in the access point, disable that.good luckOthman
1/14/2012 7:14:45 AM • Symbol AP-5131 • Answered on Jan 14, 2012
Led's indicate communication, but unable to ping device
some times your computer's firewall gets in the way, try disabling it then ping again.
1/11/2012 9:39:58 AM • Symbol AP-5131 • Answered on Jan 11, 2012
2answers
How to configure symbol 5131 through hypertrm
Hi
You can set up the AP 5131 through Hyperterminal by accessing it through COM1 to start,
19200 bits per second
8 data bits
Parity: None
Stop bits: 1
Flow Control: None.
Good Luck. :)
7/28/2010 8:30:51 PM • Symbol AP-5131 • Answered on Jul 28, 2010
2answers
Hi, I got a AP-5131 with 4 antenna outputs in the
Greetings, It is entirely possible that it has a RAM error but again this may be part of the power spike problem. Its not unusual for RAM to be affected. I don't suppose it is connected into a power spike connector? It would be wise to invest in a good one with throwouts on all plugs and use it specifically for all your PC set up. I had two router/modems affected last year ( in summer) whenj lightning is not around one would think! But there is more lightning in summer than winter according to the Gurus's of weather.
I now have all sensitive items plugged into an expensive power board with double protection fuse/cutouts and so far all has been well.
If the unit is under any warranty I would be taking it back and just complaining that is stopped working suddenly, without explanation or intervention on your part. Let them replace it. Dont ask about spike arrestors in the same shop HAHA as they may suddenly refuse to exchange it.
Ram chips are not cheap anyway, and both chips could be damaged as well as internal componenents. I don't suppose you can smell any burn in the unit? (not always evident)
Cheers
7/12/2010 8:28:48 PM • Symbol AP-5131 • Answered on Jul 12, 2010
0answers
What the IE symbol in Isuzu meter board?
'Internet Explorer' probably has a problem. Use Chrome or Firefox.
3/9/2024 3:45:01 AM • Symbol Computers... • Answered on Mar 09, 2024
My Kenwood 1 ton inverter ac outer not starting some times start show compressor symbol and then turn off and not start again doesn't show any error please guide
If your Kenwood 1 ton inverter AC is having trouble starting and sometimes shows the compressor symbol before turning off, there may be a few things you can check to diagnose the issue.
  1. Power Supply: Check that the AC is receiving proper power supply, and the circuit breaker is not tripped. Sometimes, due to voltage fluctuation, the compressor may not start.
  2. Dirty Air Filters: Check the air filters and clean them if they are dirty. Dirty air filters can reduce the airflow and cause the AC to malfunction.
  3. Faulty Thermostat: If the thermostat is faulty, it may not be able to detect the temperature properly and cause the compressor to not start. You can check this by setting the temperature to a lower level and see if the AC starts.
  4. Low Refrigerant Level: Check the refrigerant level in the AC. Low refrigerant levels can cause the compressor to not start.
If none of these steps solve the issue, it may be best to contact a professional AC technician to diagnose and repair the issue.
3/3/2023 10:16:08 PM • Symbol Computers... • Answered on Mar 03, 2023
2answers
How to type degree symbol on mac
There are a few different ways to type the degree
  1. Use the keyboard shortcut: Press and hold the Option key, then press the letter K on your keyboard. This will insert the degree symbol.
  2. Use the character viewer:
  • Go to the Edit menu and select Emoji & Symbols.
  • In the search field, type "degree".
  • Double-click the degree symbol to insert it into your document.
  1. Use the ASCII code:
  • Press and hold the Option key and the Shift key.
  • Press the number 8 on the numeric keypad. This will insert the degree symbol.
I hope this helps! Let me know if you have any other questions.
1/6/2023 8:09:59 PM • Symbol Computers... • Answered on Jan 06, 2023
2answers
British Gas T4 RF My battery symbol is flashing. Do I need to change the battery?
no info generic answer --have battery and alternator tested--check belts and connections
1/5/2023 8:41:08 PM • Symbol Computers... • Answered on Jan 05, 2023
Videocon ac remote not working
Hi, Please reach out to videocon on twitter to help take care of this issue: @VideoconIndia . You can tweet their handle with the issue included. You can also call 1800 1370 444 to reach them. I believe that is a number based in India. Thank you.
7/27/2022 11:25:03 PM • Symbol Computers... • Answered on Jul 27, 2022
How do I get firmware or a plugin for Zebra Symbol LS4278 Scanner - Model LS4278-SR20157ZZWR
Use " Scanner update utility " to update the firmware. after this try to configure scanner with " 123 scan utility " https://www.zebra.com/us/en/support-downloads/scanners/general-purpose-scanners/ls4278.html#pageandfilelist_895c
5/20/2022 10:41:28 AM • Symbol Computers... • Answered on May 20, 2022
Typewriter Brother AX-22, When typing, a wrong symbol showed up.
I lack access to the keyboard. That said, according to the manual on page 13, depressing the code button and holding it down while pressing another key will access the green symbol on that key, part of an alternate set of characters. It you see a green / mark on a key, you have your answer. https://www.manualslib.com/manual/376756/Brother-Ax-22.html?page=17#manual The page 17 you see in the link pulls up page 13 in the manual.
12/19/2021 6:06:53 PM • Symbol Computers... • Answered on Dec 19, 2021
I have a te 2200 and need to change currency symbol from euros to pounds. Please help the user manual isn't much help
The CE key is a toggle between foreign currency and local currency at a preset exchange rate. That is, it converts both ways. If this does not help, you may have to consult casio support for your region.
12/22/2020 8:36:34 PM • Symbol Computers... • Answered on Dec 22, 2020
Symbol AP-5131 Logo
17 questions posted
Popular Products
Top Symbol Computers & Internet Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Ngoro
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Symbol Computers & Internet
Most Popular Question
configure symbol 5131 hypertrm
  • Computers & Internet
