20 Most Recent Acer Aspire T180 PC Desktop Questions & Answers
How do i use the pc wizard to reset my administrator password?
You are going to need a password remover bootable .iso to burn to a CD or DVD and boot to it and follow the prompts to clear that password if you are running widows. You can also put the image on a USB flash drive if your system supports booting to USB drives? You can find the widows password remover by searching Google and where you find it will probably have instructions on the different methods to remove it. Check the link I provided out and that should get you on your way. Google
5/16/2015 1:52:14 PM • Acer Aspire T180... • Answered on May 16, 2015
2answers
How do i use the PC Wizard disc to reset my administrator password?
For windows 7 os
3/14/2015 3:25:23 AM • Acer Aspire T180... • Answered on Mar 14, 2015
4answers
Lost password after reinstallation
There are a couple methods which you can try:
When the computer first boots Windows you can press F8 to access an advanced boot menu.
From there you can choose to boot the computer in "Safe Mode" which changes the system start-up mode.
There should be a hidden user that appears as "Administrator" that you can select...
(When Windows is installed for the first time there is an option for the "Administrator" password. This password is not required and is usually left blank. If you left the password field blank then clicking on user will log you in automatically. Otherwise, you're required to enter the original password you choose to protect the system.)
Log-in into windows as "Administrator" and create a new user in the control panel that you can log-in to the system normally with.
Restart the computer and log-in under the newly created profile to regain access to your system.
If you can't log-in under your user or the administrator profile because you forgot both passwords you will have to do an advanced recovery process, or wipe the system completely.
(Here is a link for a Linux Boot CD image, burn to a disc and boot to change the Administrator password in Windows XP/Media Center/Server 2003 Systems.)
http://www.megaupload.com/?d=RI2D9V90
If this doesn't work you can boot to an alternative recovery disk, Windows CD/DVD, partitioning software, or third party password recovery tool.
When all else fails, you can delete and create a new partition; then you would have to run the Windows setup again to recover your Operating System and drivers.
8/14/2014 3:42:26 AM • Acer Aspire T180... • Answered on Aug 14, 2014
Product key
willie,if you wan't to reinstall WINDOWS do it from the recovery-partition.then you don't need the dish.let me now if you need help.
5/24/2013 12:36:17 AM • Acer Aspire T180... • Answered on May 24, 2013
0answers
Acer error
after what i understand you have to rebuild MBR (masterboot record).roberto to able help i need moore information.can you get in to safe mode ? .
5/21/2013 5:48:22 PM • Acer Aspire T180... • Answered on May 21, 2013
6answers
I forgot my e-recovery password, no recovery disks...
Don't you have created the password Recovery disk early?
If you do, you can sign into safe mode and recover the password.
If you don't have the password reset disk. you have to take use of the 3rd party utility,
Windows Password Recovery 6.0 is highly recommend. It is fast and easy to use.
11/19/2012 8:29:07 AM • Acer Aspire T180... • Answered on Nov 19, 2012
My desktop question isn,t answered for a acer aspire T180
you have to post a question ? before some one can post an anwer post a reply
11/6/2012 10:19:25 PM • Acer Aspire T180... • Answered on Nov 06, 2012
It keeps comming up with verifin pool data then FWYSK is compressed pres ctrl then alt the del to restart but i do that and its come back to message what is the problem
sorry it says verifing DMI POOL DATA ..... FWYSK IS COMPRESSEDPRESS CLTR +CTRL+ DEL TO RESTART I PRESS THOSE AN IT GOES OFF then come up with the message it i did put 2x1 GB MEMORY STICKS IN THE DAY BEFORE BUT IT WENT OK THEN MOVED SOME FILES FROM C DRV TO DRV THEN DID OTHER STUFF TURN OFF THE COMPUTER FOR THE NIGHT TURned on in morn but that came up for the first time it is a acer aspire T180 DESKTOP
11/6/2012 9:28:13 AM • Acer Aspire T180... • Answered on Nov 06, 2012
Computer powers up but no signal to mointor and the perphial accessories work but the power button doesnt com on or turn off the power
Unhook everything but the CPU, memory, and video. Does it start up? Can you see anything on the monitor?When you were messing around inside the box, you may have accidentally removed the wires from the motherboard that control the power switch and the power light. Check that you haven't done that and if you have, reattach the little plugs to the pins where they belong.If you don't get anything, the motherboard is probably toast.
10/23/2012 10:13:49 PM • Acer Aspire T180... • Answered on Oct 23, 2012
Acer aspire t180 stuck on logo screen
try booting in safe mode by tapping f8 during boot
10/9/2012 7:24:05 PM • Acer Aspire T180... • Answered on Oct 09, 2012
HELP! Acer T180 is possessed!
Have you Googled the beep codes? This is most likely your solution. You should do the RAM test on your system. Blue Screen Of Death
  • Remove all USB attached devices.
  • You may need to roll back system with System Restore. Under Safe Mode (press F8 during boot and choose safe mode). Start > Search type System Restore. Now choose a date prior to problem. You may have to try a few dates.
  • Uninstall last program(s) that was installed, again in safe mode.
  • Test one DIMM at time. One slot at a time. To eliminate possible bad RAM. Unplug PC. Opening case. Remove all RAM. Use static precautions!
  • Re-install Windows. Clean install works best. All data will be lost.
  • Lastly you may have other hardware problems. If it does another blue screen after reloading windows, especially with a clean install.
10/5/2012 11:47:44 AM • Acer Aspire T180... • Answered on Oct 05, 2012
Can i still restore my computer to factory if i have removed empowering technology?
yes you restore with the rescue disk
9/4/2012 6:19:49 AM • Acer Aspire T180... • Answered on Sep 04, 2012
Microsoft Game Launcher has stopped working need a solution
Try This:> 1 - Left click on Start> 2.- Right click on Computer> 3 - Left click on Properties 4 - Left click on Advanced System Settings> 5 - Under Performance click on Settings> 6 - Left click on Data Performance Settings (on my computer the tab said> Data Execution Prevention)> 7 - Click on TURN ON DEP FOR ESSENTIAL WINDOWS PROGRAMS AND SETTINGS ONLY.> 8 - Click on Apply and then OK.>> UAC: (User Account Control)> Open up Control Panel, and type in user account into the search box.> You'll> see the link for "Turn User Account Control (UAC) on or off". Click it.> Uncheck the box, and reboot your computer.Good luck!
8/22/2012 7:30:30 PM • Acer Aspire T180... • Answered on Aug 22, 2012
Memory card won't fit into orange slot
that is a good idea to match the memory cards like matching four tires on same carda bit concerned about 'forcing ' them into the slots though
5/25/2012 5:18:13 PM • Acer Aspire T180... • Answered on May 25, 2012
Acer aspire t 180 cant get pc to recognize digital camera photo memory card
Has the computer recognized the memory card in the past? If so, try download and reinstalling the memory card driver.
Get online and got to www.google.com In the google search box type: "Acer Support" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operating system when requested. Download and install the Card Reader drivers.
If after installing the drivers the reader still does not work, you can purchase a multi format card reader that will plug into you usb port from Tiger Direct for less than $15. at
http://www.tigerdirect.com
When the site comes up just put in the search at the top "SD Card Reader or XD Card Reader" depending you your type and press GO. You can sort the returned results by Price Low to High.
Do you have a USB Cable that came with the camera that you can plug into one of the usb ports on the computer? If so, try that. It's another way of getting pictures off the camera. Plug the cable on the camera and into the computer then turn the camera on. The computer will recognize the camera and install the drivers. You can navigate through the camera folders just like you do any other device to find the pictures.
5/14/2012 2:26:22 PM • Acer Aspire T180... • Answered on May 14, 2012
Tried to run system restore but get error @the file q12300.sys is corrupted
what were the last 3 activities you performed with the pc, before the blue screen and needing to restore
5/13/2012 8:25:32 PM • Acer Aspire T180... • Answered on May 13, 2012
My computer will not power up
problem may be with *********** board.just test whether its fine
5/6/2012 4:53:31 PM • Acer Aspire T180... • Answered on May 06, 2012
Acer Aspire T180 PC Desktop Logo
94 questions posted
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
View Most Popular
Aspire Acer
  • Aspire Acer
Most Popular Question
aspire t180 pc desktop i forgot my e rec
  • Computers & Internet
