20 Most Recent
La Pavoni Jolly (PA-JL) Electric Burr Grinder Questions & Answers
How to change burrs
1 take the bell(bean container) carefully out.
2 disassemble the upper holder of burr
3 you will see now the burrs, clean good coffee remains than disassemble the burrs
4 after disassembling burrs clean good the lower and upper burr holder.
5 carefully switch on the grinder tan switch off(few seconds) during lower plate is rolling touch with marker the surface of burr holder very softly, if it is ok you will have complete circle / if it is deformed you will have incomplete circle( that you must compensate with letter tape ) after each correction you mark the burr with marker to see did you achieved perfect result.
once you have lower burr in place you screw bolts in upper bur holder and assemble it back in his place.
La pavoni slow water flow
Try running some white vinegar through it as if you was making coffee (but don't use any coffee) and when done either repeat processes or run a clean pot of water to clean out the vinegar and see if the water is coming out faster. You might need to repeat process a few times. The vinegar breaks down any hard water residue.
What causes my la pavoni europicola to make a whistling when it;s turned on?
hi
it is normal when water heating up and pressure begin to be built in the boiler until the vacuum braker at the safety valve close
but if it continue to whistle when the green light goes off
after few minutes it means you have too much pressure in the boiler and it is realesed through the safety valve
in that case you have to replace your pressurestat or you have scale at the bottom of boiler in the entrance of the pipe leading to the pressurestat
regards
Guy
Coil sealant
HI you shouldn't use sealant. if the silicon seals are broken they should be replace, they are available from sellers on ebay.
Hi what size tamper do i need for la pavoni ebr machine about 12 yrs old thanks
Hi I have one of these in the attic, they do not come with a tamper as they have a fancy pressurised portafilter , its good to level the coffee and if I remember I did used to give it a bit of a tamp as it just didn't seem right not to. I have found a couple of references to tamper size on the web and both say 53mm I can't totally vouch for this though, you can always check with a ruler.
