20 Most Recent Toastmaster TUV48 UltraVection 1400 Watts Toaster Oven with Convection Cooking Questions & Answers
Need a manual for the toastmaster tuv48e convection oven
get the manual here
10/2/2012 8:29:45 PM • Toastmaster... • Answered on Oct 02, 2012
Need to buy the basket
MY BASKET IS SEPERATED FROM THE GLASS WHICH MAKES THE DOOR NOT SHUT PROPERLY CAN YOU PURCHASE THE DOOR WITH BASKET ATTACHED?
7/30/2012 7:03:48 PM • Toastmaster... • Answered on Jul 30, 2012
Describe your TUV48E UltraVection 1400
Hello, rbI was trying to help you out here. Maybe this will help some? I was going backto some customers that asked questions in the recent past and even fartherback. It appeared that no one answeredsome of them, So, I thought I would take some of my personal time to see if Ican help. Even though this Informational site may not have your exact model orbrand, this site will help you a lot. Here is a site link about everything you want to know about toasters andpossibly yours, from repair to trouble shooting it. http://home.howstuffworks.com/how-to-repair-small-appliances1.htmPlease if this helped you at all, if you can find the time and in your heart torate my help and some kind words written would be appreciated for my free help, I would appreciate it. Here is also my direct link to my own pages of other areas of my expertise forother problems you might have in Automotive, Appliance, and Electronics. DropIn anytime for my help.Thanks, Mikehttp://beta.fixya.com/users/mc1bean
10/28/2011 11:03:42 PM • Toastmaster... • Answered on Oct 28, 2011
2answers
Does not heat up.
Mine worked for awhile, then started overheating. I (former appliance repairman) found that the fan needed oiled. While I was checking it with the outside covers removed, I saw that two of the connections on the top heating element were arcing and burning! This accounted for a strange smell.
9/5/2011 12:47:27 AM • Toastmaster... • Answered on Sep 05, 2011
I have a 2001 toastmaster
Hi Milesne,
You will first need to open it.
- > Follow the Power cord into your machine, look for a fuse or a thermal fuse on the way to it's destination (The Main PC Board) Fuses & Thermal Fuse examples:
Normal Fuse:
Thermal Fuse/Cutout (Can be various sizes & colors):
Check these components first, what might have happened is that the element may have tripped (Fuse) or the cabinet got too hot thus activating the safety cut-outs (Thermal Fuse/Cut-Out) - If the culprit is found, it needs to be replaced. Found at most Appliance Spare Outlets.
Also, I believe this wiring diagram will work for your machine, might help you:
Kind Regards & Good Luck d")
JEDEMEYER1
* If this solution helped you, please accept it
8/2/2011 6:36:13 PM • Toastmaster... • Answered on Aug 02, 2011
3answers
Manual for TUV 48S ultravection oven
You have to register at Kitchen Manuals before you can download it.
http://www.kitchenmanuals.com/manuals/mfg/toastmaster/tuv48_tuv48can.html
6/6/2011 2:51:40 PM • Toastmaster... • Answered on Jun 06, 2011
I would like to buy one are they in stores, like
You can check the nearest authorized sales office of the toastmaster products at http://www.middleby.com
6/6/2011 2:16:04 AM • Toastmaster... • Answered on Jun 06, 2011
AskaHow can I either get
Hi -
You can download the user manual for the Toastmaster TUV48E by clicking on this link.
http://dl.owneriq.net/0/0adc711e-85ab-4238-a68a-19394579d13e.pdf
The manual will open in a new browser window. Once the manual is open you can print it and/or save it to your PC. If you are unable to open the file, you will also need to download and install the latest version of Adobe Reader:
http://get.adobe.com/reader/
Please allow up to 2 minutes for the manual to load after clicking on the link. The manual says TUV48 / TUV48CAN but it's identical to the TUV48E.
Hope this helps. If you have any difficulty downloading the manual please let me know. You can reply to me by clicking on "Add a Comment" below your question.
Regards,
BElectric
4/5/2011 1:09:26 AM • Toastmaster... • Answered on Apr 05, 2011
REPLACEMENT LAMP
Try this address for a list of sites that sell oven parts.
netshoppers.com/search/index.php?phrase=oven+parts&uid=d5d00793c96dccbcaa9b5f3ca3d412cd&kuid=4c4a6ef184c15b7eeffee322a7d94921&src=7s
<a href="http://www.toasterandconvectionovens.com">ToasterandConvectionOvens.com</a>
2/18/2011 8:07:21 PM • Toastmaster... • Answered on Feb 18, 2011
0answers
Our Healthy Cooking Guide that came with our
make the Guide wet again and then try to seperate the pages (soak it)
good luck !!
7/8/2010 3:12:02 PM • Toastmaster... • Answered on Jul 08, 2010
2answers
Fan works timer works but no heat
There is no fuse. Take back cover off and all bottom perimeter screws. Outside cover pulls off towards rear once you get all the ** little screws out. Chances are you will find burned connections on the heating elements poking out the sides of the heating chamber. Try cleaning these and squeeze them tighter before reconnecting. Good luck!
4/22/2010 11:03:24 PM • Toastmaster... • Answered on Apr 22, 2010
Electrical wires connection
Placed the item in the trash can.
Thanks
12/7/2009 12:16:31 PM • Toastmaster... • Answered on Dec 07, 2009
3answers
Manuel for TUV48E toastmaster oven
Finally found a link. I've been looking for months, all the links 'where not found'. Hope it works for you.
4/5/2009 12:02:45 AM • Toastmaster... • Answered on Apr 05, 2009
Ttm602 toaster,browning one side ,even
The problem is with the heater (bars) connection, which would be under the cover on the left side. Caution ! You're dealing with electricity which may cause a fire. That said, the solderless connecters on the heat elements and the wires probably need replacing,that's all,I did it to mineand it worked. DON'T forget the caution!!!!
3/26/2009 9:15:15 PM • Toastmaster... • Answered on Mar 26, 2009
I have the manual and the plastic cooking time insert. I can scan it and send it to you.
2/18/2009 10:01:49 AM • Toastmaster... • Answered on Feb 18, 2009
2answers
Manual please for Toastmaster TUV-48
I have the manual. I can scan it and send it to you.
2/2/2009 12:19:28 AM • Toastmaster... • Answered on Feb 02, 2009
Hello. I have a ToastMaster
I can send you the notice I have the same oven give me your mail and I send it to you.
Have a good day
1/2/2009 2:32:12 PM • Toastmaster... • Answered on Jan 02, 2009
How to use
Toastmaster TUV48
12/10/2008 10:18:41 PM • Toastmaster... • Answered on Dec 10, 2008
Toastmaster TUV48 UltraVection 1400 Watts Toaster Oven with Convection Cooking Logo
41 questions posted
Top Toastmaster Toaster Ovens Experts
ADMIN Andrew
ADMIN Andrew
Kardoc
Are you a Toastmaster Toaster Oven Expert? Answer questions, earn points and help others
