20 Most Recent M-Audio US85100 Keyboard Questions & Answers
If your Macintosh computer won't turn on, here's how to troubleshoot it. Please keep in mind that although your computer may display similar symptoms that prevent it from showing video, this article discusses what to do if the computer won't turn on, meaning that when you press the power button:
  • You don't hear a startup chime
  • You don't hear any fan or drive noise
  • The power button or power indicator doesn't light up at all
If your computer doesn't display any video, it may display one or more of these similar symptoms when you press the power button:
  • You may hear a startup chime
  • You may hear fan or drive noise
  • You may see the power button or power indicator light up
If any of these conditions occurs, see the Troubleshooting: My computer has no video article instead. If your computer won't turn on, try each of these steps:
  1. Make sure that the power cord is plugged into a working wall outlet, and that it's properly connected to the power adapter. (To check if the wall socket is working, plug in a lamp or other electrical device.)
  2. Make sure that the power adapter is properly connected to the power port on the back of the computer.
  3. Disconnect all accessories that are plugged into the computer, such as a printer, hub, or iPod.
  4. Reset the computer's PMU or PRAM.
    • For a portable (iBook or PowerBook), click here for instructions.
    • For a Mac mini, click here.
    • For an iMac, click here.
    • For a Power Mac, click here.
    • For a Mac Pro click here.
    • For a MacBook or MacBook Pro, click here.
    • For any other computer, click here for instructions on resetting the PRAM.
  5. Try plugging a different power cord into the computer (if you have a working one available). If the computer starts up, replace the old power cord. You can get a replacement cord for some models here.
  6. If the computer uses a power adapter, try connecting a different power adapter to the computer (if you have a working one available). If the computer starts up, replace the old power adapter. (Computers that use a power adapter include MacBook, MacBook Pro, iBooks, PowerBooks, Power Mac G4 Cube, and Mac mini.)
  7. If you tried all of the steps above and the computer still won't turn on, contact Apple technical support (1-800-APL-CARE in the U.S.) or take your computer to your local Apple Store or Apple Authorized Service Provider (AASP) for diagnosis.
M-Audio US85100... | Answered on Oct 19, 2014
open the keypads, and clean withaa9b8f5e-0120-4d21-b5b6-7a30584f3c24.jpg contacts cleaner, from dirty, oxide, corrosion, clean the contacts batteries , and replace by new ones.
see the diagram use digital camera, the LED must be TURN ON.
resolder any colder joint.
God bless you
M-Audio US85100... | Answered on Jul 25, 2013
Hi !Have you try to install the latest driver?Go to the following page, Select you product and operating system, download and follow the instructions.
http://www.m-audio.com/index.php?do=support&tab=driver
Hope i helped,omerk.
M-Audio US85100... | Answered on Feb 27, 2011
Not sure that this info will be of use to you, and i have not tried this on any keyboard, but i had a similar experience with a scale that has a digital display. When i took the thing apart to change its battery i found that the display was actually like a piece of glass. On one edge was a rubber like strip that was the interface between the display and the circuit board. This piece was not seated well against the display part and so the information from the circuit board was only partially making it to the display causing the same sort of result that you describe that you see with the keyboard. You may be able to open up your board and just fiddle with the parts, put it back together and it might start working for you. I had to sort of shim the display with a thin piece of material to get the display to maintain better contact with the rubber strip part. Hopefully, this info will be useful. Good luck!
M-Audio US85100... | Answered on Dec 28, 2010
Music Stores
Music Equipment at Guitar Center. Free Shipping on 1000's of Items!
GuitarCenter.com Music Cd's at Amazon.com
Low prices on Music Cd's. Qualified orders over $25 ship free
www.Amazon.com Morey's Music Store, Inc
1-562-420-9532
4834 Woodruff Ave
Lakewood, CA
View More Info Morey's Music Store, Inc 1-562-420-9532
4834 Woodruff Ave
Lakewood, CA 90713
Types of Instruments SoldBand & Orchestral, Guitars & Fretted Instruments, Print Music Store InformationInstrument Rental: Yes Lesson InformationLessons: Yes Instrument Repair InformationViolins, Viola, Cello, & String Bass Repair HoursMonday - Friday 10:00AM-6:00PM
Saturday 9:30AM-5:30PM
Sunday - Closed DetailView(32889724, 'Morey s Music Store, Inc'); Alley Kat Sheet Music Cent
1-714-229-8528
9203 Valley View St
Cypress, CA
View More Info Alley Kat Sheet Music Cent 1-714-229-8528
9203 Valley View St
Cypress, CA 90630
Types of Instruments SoldPrint Music DetailView(32889988, 'Alley Kat Sheet Music Cent'); Marshall Music
1-310-320-0246
503 Van Ness Ave
Torrance, CA
View More Info Marshall Music 1-310-320-0246
503 Van Ness Ave
Torrance, CA 90501
Types of Instruments SoldElectronic Keyboard, Band & Orchestral, Drums & Percussion, Sound Reinforcement, Guitars & Fretted Instruments, Print Music DetailView(32889601, 'Marshall Music'); Jcs Charis Corp
1-562-809-3886
13201 South St
Cerritos, CA
View More Info Jcs Charis Corp 1-562-809-3886
13201 South St
Cerritos, CA 90703
Types of Instruments SoldPrint Music DetailView(32889996, 'Jcs Charis Corp'); Carpenter Music Store
1-310-534-8863
2830 Sepulveda Blvd
Torrance, CA
View More Info Carpenter Music Store 1-310-534-8863
2830 Sepulveda Blvd
Torrance, CA 90505
Types of Instruments SoldDrums & Percussion, Sound Reinforcement, Guitars & Fretted Instruments, Print Music DetailView(32889683, 'Carpenter Music Store'); Whittaker Music Inc
1-562-598-2461
2222 N Bellflower Blvd
Long Beach, CA
View More Info Whittaker Music Inc 1-562-598-2461
Long Beach, CA 90815
Types of Instruments Sold Electronic Keyboard, Print Music DetailView(32894622, 'Mattina Music Co'); Piano Shop,The
1-310-530-5300
25925 Cypress St
Lomita, CA
View More Info DetailView(32889645, 'Piano Shop,The'); Fantastisound
1-714-599-7972
5840 Crescent Ave
Buena Park, CA
View More Info
M-Audio US85100... | Answered on Dec 14, 2010
Here is reference to one of the best blogs I have found online for disassembling the KS Pro 88, because this one includes photos.
http://ratula.net/eblo/archives/000438.html
Best regards, JSR
M-Audio US85100... | Answered on Sep 04, 2010
use on screen keyboard and type your keys if this work then it is hardware problem if not then it is a virus scan it
M-Audio US85100... | Answered on Mar 27, 2010
take it apart, wipe up any remaining water and let it air dry for 24hrs. Put it back tgether and see if it works. If it does you're lucky, if not start taking apart your wallet to fix it. HTH.
M-Audio US85100... | Answered on Feb 14, 2010
Try looking for updated drivers / software patches on the maunufacturers website. as it is possible that this is a known issue
M-Audio US85100... | Answered on Dec 13, 2009
Check your computer setting - You should check play options or similar. You dont ID the computer nor operating system so it is hard to be more specific.
On my Midi Device with USB connection, I have a choice of Microsoft routine or other routine. When set to Microsoft setting, my midi keyboard works.
I hope this helps you
thanks for your interest in FixYa.com
Please vote
thanks
a
M-Audio US85100... | Answered on Dec 04, 2009
If you can take it into a shop it will be about 35 and if it involves a house call at least 75
M-Audio US85100... | Answered on Jul 11, 2009
When you turn on your keyboard, you have to make sure that your foot isn't on the pedal because that will cause the notes to be sustained. Just wait until the keyboard is on to push the pedal.
M-Audio US85100... | Answered on Nov 29, 2008
With the "Sing-spiration" only 3 hours away, we, John Cobb (the keyboard player) and I, decided to jump in and find the problem.  We removed the covering on the backside, removed the keyboard from the base, and when we saw the bottom of the keys, found a broken counterweight.  It was from the mid-G key that wouldn't work.  John said he doesn't use the high-G key much, so we took the good counterweight off of high-G and replaced the broken weight.  After replacing enough screws to keep the keyboard assembled, John "tested" it for the nites playability.  All is great!  We'll go to the local music store today and order a new counterweight.
The Sing-spiration was a great success!
cuinsemo
M-Audio US85100... | Answered on Sep 22, 2008
M-Audio US85100 Keyboard Logo
Popular Tags
37 questions posted
Top M-Audio Computers & Internet Experts
Edward Easley
Edward Easley
John Bolton
Thomas F. Schneider
Are you a M-Audio Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • M-Audio Computers & Internet
Most Popular Question
prokeys 88 premium stage piano key
  • Computers & Internet
