20 Most Recent
LG LRE30451ST Electric Kitchen Range Questions & Answers
LG Range #LRE30451SW
This happened to me on Christmas Day morning & it happened once before. I finally remembered how I fixed it. Push the "Clear" button & then push the "Start" & keep it held in until you see the lock button light up (takes awhile - be patient) & then push the "Clear" button again. After I did this the "Clock" worked again - reset the clock to the correct time & push "Start" Then click on "Bake" set your temperature & push "Start". Hope this works for you. It got me out of cooking Christmas Dinner!!!
Lg lre30451st right front/right rear burners won't come on
I tried this on the advice of another post. It worked for me and now all of my burners are working again!
HOW TO OPERATE LG STOVE
hi there just visit lg.com support. and there you can download the full user manual. hope this helps
F-1 oven error keeps coming
Hi
Error
code F1 means that an error with the keypad has occurred. Usually it happens
due to loose ribbon cable on the keypad or the electronic control assembly
itself going bad. To resolve this issue first, disconnect the power to unit and
then gain access to the back of the clock assembly (Electronic Range
Control/ERC). Now unplug the touch pad ribbon connector from the ERC, it would
be a flat wire approx. 1 1/2" to 2" wide and make sure that the cable
is not broken and nothing is shorted on the keypad. After this is done insert
the cable back and then plug the unit back to check. If the error is still
there then the electronic control board should be replaced. Hope
this helps...please post back for further assistance.
Daniel
