20 Most Recent
Combi Steamer electric built in steam generator Oven Questions & Answers
STEAMER NOT WORKING SHOWING E8 FAULT
Hi, error 8 is showing you there is something wrong with temperature control pot. This is soldered to the pcb so you need to get someone to replace this or check the connections, otherwise the pcb needs replacing
How to tighten loose handle
Remove the door gasket, that should give you access to removing door plate. Door handle may need to be replaced.
Not steaming
check the holes have not gummed up from residue in the steam. It builds up over time.
I need manual for electrolux combi oven cs20
You can down load one right from a google search for such.. You could also look up customer service for Electrolux and contact them by phone to request one but you may have to pay a small fee.
