20 Most Recent
Ionic Pro TURBO Air Purifier Questions & Answers
Where is the ionizer wire?
On the opposite half as the plates. Look for but don't touch the big insulator at the top. The wire run from it to the bottom of the machine. Older ones have a cleaning bead and you must turn the entire machine upside then right side up several times to clean it. Mine had a latch on the back top with a label, " pull up to clean if crackling". I pulled it up and observed a wiper sliding up the big wire inside. I did it up and down several times and that fixed mine.
Ionic pro turbo
You need to clean all the stainless steel contact points inside the unit, not just the blades. Make sure you unplug the unit before doing this.
Why does clean stay on
it has a reset function hold down power 5 sec otherwize check to see if there is any dark spots on the bottom before reinserting. 1st make sure its unplugged then 2nd there should be a copper set up as if putting a 9 volt battery into a fire alarm. there should be two side by side the darkening is where either cleaner was left still dripping or a dust partical probably from the paper towel. caused a static charge. use a Q tip to clean it . and always make sure it is dry if u hear a static sound unplug it is still wet.
