20 Most Recent
Airtemp B3Q06F2A Air Conditioner Questions & Answers
I have an older a/c
My thought is that your situation is humidity related. If anything were wrong with the A/C process, the unit would stop cooling....Remember, that the process of air conditioning (cooling) removes some moisture from the air...So it is unlikely you have an issue......
What type of wall plug can I use for this air
If it is a 110 unit,use a regular wall receptacle ,if it is a 220 unit,use a 220 receptacle for 220 it will be made larger and different.Draw a picture of the plug on the end of the cord and go to the hardware store and get them to help you i d the plug.some 110 units are 40 amp,and are a little different than the regular 110 house hold 20 amp receptacle.
Dimensions
by dimensions do you mean the physical size or the capacity in BTUH? you should get a machine that will fit in your window and if the A/C cooled the room ok get one that matches the BTUH output.
Looking for btu on airtemp imperial ll model
This information can usually be found on a small plate welded or glued onto the side/rear of your A/C units along with the model & serial #s. Although it would be a highly illogical place to put this plate, you may also want to check the bottom but if you turn the unit upside down, do not turn it on for 24 hours, as the gas & oils will be displaced & you can kill off the compressor by doing so.
