20 Most Recent
Kaz Home Environment Replacement Ultraviolet Light Bulbs for Honeywell HFD-135 Air Purifier Air Purifier Questions & Answers
I have a Kaz Honeywell
Check
to see if there is power getting to your device. If it is a
110-volt unit, plug a lamp or other device into the same outlet the device is plugged into. If there's no power, check the fuses or
circuit breakers. If there's still no power, you will need to contact a
qualified electrician to restore power to the outlet.
If there is power to the appliance but it is still completely dead there may be a problem in one or more of the following areas:
Wiring (Inspect for any broken or burnt wiring)
Selector switch
Control board
Work on these areas of an appliance may require help from an appliance repair person or other qualified technician.
Take care.
10/10/2010 9:26:29 PM •
Kaz Air...
Answered
on Oct 10, 2010
I need UV replacement BULB , I cant find one online
There are a few things you can try if you're having trouble finding a replacement UV bulb for your device online. One option is to check the manufacturer's website to see if they sell replacement bulbs directly. Many companies will also list authorized resellers on their website, so you may be able to find a replacement bulb from a trusted third-party seller.
Another option is to try searching for the bulb using the model number of your device. This will help ensure that you're getting a replacement bulb that is specifically designed to work with your device.
You can also try searching for the bulb using keywords related to the device, such as "UV water purifier bulb" or "UV air purifier bulb."
If you still can't find the right replacement bulb, you may want to consider contacting the manufacturer directly to inquire about replacement options. They may be able to provide you with the information you need or point you in the direction of a trusted reseller.
If online search not working you can try a local store that sell electronic part, Home improvement stores that carry a variety of lighting options may be able to help you find the UV bulb you need.
Please do let me know the model number or application the UV light is used for, so that i could provide specific recommendations.
