20 Most Recent
Craftsman 5-1/2" Trim Saw, C3-19.2 Volt Cordless-g17 Questions & Answers
How to install drive belts on a craftsman table saw model # 218290?
Remove the side panel (key number 21) the dust cover (key number 23) guide holder (key number 29).
Use a 19MM or a 3/4 inch deep socket with a long extension and ratchet. This will keep your hand out of the way.
Now rotate the arbor counter clockwise and deflect the top edge of the belt downwards onto the arbor to catch the grooves.
Continue to work the belt around and checking at the motor shaft.
Once the belt is in place work it down by deflecting the top edge of the belt.
reference > http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Saw-Parts/Model-315218290/0247/0744600?pathTaken=&prst=0&shdMod=315218290
How to remove the bearing #30571 on a Craftsman Radial Arm saw model 113.29003
Removing bearing #30571 on a Craftsman Radial Arm saw model 113.29003 can be a bit challenging, but it can be done with the right tools and techniques. Here are the steps you can take to remove the bearing:
- Unplug the saw from the power source.
- Use a wrench or pliers to loosen and remove the bolt or nut that holds the bearing in place.
- Carefully remove the bearing from the saw. If it is difficult to remove, you may need to use a bearing puller.
- Clean the bearing and the area around it with a clean rag or brush.
- Inspect the bearing for any damage or wear. If it is damaged or worn, it will need to be replaced.
- Once the bearing is removed, cleaned, and inspected, install the new bearing if needed, and reattach the bolt or nut to hold it in place.
- Before turning the saw back on, make sure to test the saw operation before using it.
It is important to mention that this is a general guide, the exact steps and tools may vary depending on the particular model, so you may want to consult your saw's manual or the manufacturer for more specific instructions. Also, be aware that working with any power tools can be dangerous, always use the appropriate safety gear and take caution.
How modify pole saw blade
Saw blades are tempered steel and you would need to use good drill bits to get a clean hole. You also need to use a center punch to mark and start the hole.
Where can I find motor parts for a craftsman table saw model 137.248481
Using Sears parts direct, i could not find one part you listed. I suspect you have ruled out replacing the motor and finding the same table saw often for free on Craigslist.I see ereplacement parts has little inventory.ebay has brushes. Any brush for 137 series should fit.hope this helps some.
