20 Most Recent
Spectroniq Portable 7" Widescreen DVD Player Questions & Answers
Dead
The power supply board probally dead,not worth repairing,beacuse the power supply board part and the labors of the Tech. the cost to u could be same amount of money to buy a new one.The new one cost only about $100 dollars.
How to program remote control pltv3250 to spectroniq tv pltv4250 lcd 42
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "
brand name" to your device; in the "
Search box at the top right of the display window" to get gathered related posts.
11/24/2016 12:45:00 AM •
Spectroniq...
Answered
on Nov 24, 2016
I DONT HAVE THE REMOTE FOR THIS TV SO IM TRYING TO PROGRAM THE REMOTE
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://electro-medical.blogspot.com/
How to programme a irc1597 remote for a baird 32 pr2 tv
Direct Code Entry
- Press and hold the SETUP button until the red indicator stays on, then
release the SETUP button.
- Press and release the desired Mode button (TV, VCR, etc.). The red indicator
blinks, then stays lit.
- Enter the 4 digit code from the code tables. Note: after a valid code entry,
the red indicator turns off. For an invalid code, the red indicator flashes.
- With your device on, press CHANNEL UP. If the device responds, no further
programming is required. Note: If some buttons do not operate your device, try
one of the other codes for your brand.
- Code SearchIf after trying "Direct Code Entry" your device does not respond, or if your
brand is not listed, try doing a search of the code library for your code by
following these steps.
- Manually turn on the device (TV, VCR, etc.) to be controlled.
blinks once, then stays on.
- Press the CHANNEL UP button repeatedly (up to 300 times) until the device to
be controlled changes channel. The red indicator blinks, then stays lit.
- Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes
under CBL, etc. If you want to store a VCR code under CBL, etc., first follow
the procedure for Direct Code Entry and press CBL in step 2 of Direct Code
Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the
steps above for Code Search.
It loads an says wrong disc
There really should be something on it identifying the make and model - check the underneath. Assuming you;ve tried various discs to eliminate chance its just a dodgy disc, it will be the lens either dirty or misaligned, I think. If you bought it new it shouldn't be dirty. If you bought it from a store either new or used you should just take it back. You can get lens cleaners from places like WIlkinsons and Debenhams for under $10 but I cant recommend them too strongly - bit hit and miss in my experience. If cleaning doesn't work it will likely be a repair job or bin it - it wont be anything to do with settings or that you're doing anything wrong (unless putting the disc in upside down or something!), so unless a lens cleaner works, you're only option would be to have it repaired. If you knew make and model you might find diy repair instructions on internet but I'd suggest unless you're quite handy it's not easy. I have had a number of cheap dvd players over the years and it does seem to be an area where you get what you pay for - they've generally been unreliable and in some cases had an extremely short life.
