20 Most Recent
Benchmark 11065 Popcorn Maker Questions & Answers
Hi. I have a brand new Benchmark Premiere 6 11068
could be that the bowel had a thin plastic protection on it when new that should have been peeled off before starting it up
could be a wire touching the hot bowel and melting
what ever , it is under warranty so take it to a service dealer or authorized repair shop and have it checked out
smoke and smell are food contaminants so the cause has to be found for safety reasons
Kettle does not work
you have probably re-wired the switch incorrectly or there is water in the wiring and the circuit is shorting, causing the fuses to blow. Also, is your electricity supply 120v or 240v?
Paragon spin magic 5qr, when spinning causes bowl to shift.
Athletes often talk about the need to find "the zone." This is a state where everything seems to come together and they are able to achieve feats they never thought possible. For bowlers, this zone is often referred to as "the spin zone." When bowlers are able to get their bowling ball to rotate quickly on the lane, they can cause the ball to move in unexpected ways.
2/8/2024 2:23:46 PM •
Kitchen...
Answered
on Feb 08, 2024
Gett motor out of toledo meat slicer
Removing the motor from a Toledo meat slicer involves several steps. First, unplug the slicer to ensure safety. Locate the motor, typically positioned near the base. Depending on the model, you may need to remove a cover or access panel to reveal the motor. Disconnect any electrical connections, such as wires or cables, linked to the motor. Next, loosen and remove any securing bolts or screws holding the motor in place. Carefully lift the motor out of its housing, ensuring that no other components are obstructing its removal. Exercise caution and refer to the specific user manual for your Toledo meat slicer model for precise instructions.
2/3/2024 5:14:04 AM •
Kitchen...
Answered
on Feb 03, 2024
