20 Most Recent
Desa International GWN6 Compact Heater Questions & Answers
Pilot light goes out after thermostat kicks off
If it's a direct spark ignition type heater maybe that's how it's designed to.work .When called for heat pilot open allowing gas then ignitor spark and ignite the pilot then gas valve open and allow gas through burner then unit fires off .
Once temp is met pilot valve closes and pilot out .
2/19/2018 12:59:43 PM •
Desa...
Answered
on Feb 19, 2018
I HAVE A DESA MODEL T36 NRA
I have same model, went to all parts.com and ordered pilot assembly for 105$ , has all in one kit.
Part # 108084-02 easy instal
Good luck
9/24/2013 8:56:59 PM •
Desa...
Answered
on Sep 24, 2013
Comfortglow modle cgn30tb @cgn30tlb,,,,light it and it burns good for 5 or 10 min,,,starts hissing and then poof it goes out..has been working fine up till now,,,,
Why gas log fireplace releasing black soot
Logs are likely not placed properly on the burner. Option two is if they are a vented gas log soot is normal, but only on vented sets. Unvented Logs will be soot free. Soot is a sure sign of Carbon Monoxide. Install a detector if you do not have one.
2/10/2013 11:44:21 AM •
Desa...
Answered
on Feb 10, 2013
Ods sensor needs replacing
You will have to purchase an entire pilot assembly. Contact manufacture and purchase or find a distributor.
2/10/2013 11:31:02 AM •
Desa...
Answered
on Feb 10, 2013
