20 Most Recent
Miele 36 in. KM3474 Gas Cooktop Questions & Answers
CAN YOU GET THE GLASS
Hi anina266,
It comes with the trimming unfortunately.
Part number: 23022302
Kind Regards
JEDEMEYER1
* If this solution helped you, please rate it
Miele KM 3474 stove top lights but turns off after 30 seconds
Does the burner attempt to re-ignite after it goes out? If so, it's probably the therocouple. If not, it could be the burner valve. Be sure the caps and rings are correctly seated on the burners and be sure to firmly press the burner knob down to start the flame.
I have looked all the site for MIELE parts, but
you can only purchase Miele parts from Miele and no one else other than authorized Miele service agents and it is the same price. you would also have to call them as parts are not on line
Miele induction stovetop error FE31? It caused my fuse to blow but now can't get it to work. Any ideas?
Finally I found the meaning of FE 31.
FE31 means "control panel is dirty" or "some object is on the control panel"
When error code FE31 appear on the control panel, clean the control panel area with clean wet paper towel or remove any object on the control panel.
If you do not trust me, turn on the cooktop and put small piece of paper towel on control panel. You cannot see FE31 error code soon. Turn off the cooktop and remove the piece of paper towel, the error code EF31 will disappear.
Miele HR1124 cooktop - turning one burner on keeps igniter clicking for all 4 burners.
It is a gas appliance and it is a Miele, so you need a registered gas technician to service it. In my experience, the spark igniters work on all burners. To clean the burners, remove them all and put them in a large saucepan. Add cold water and dish liquid, bring slowly to a simmer and turn off. When cold, rinse and scrub with a plastic pot brush, paying particular attention to holes and slots. This was a job we did in the restaurant every week. It is a good plan to do before you go to bed for the least disruption.
The product specs says;
Automatic re-ignition
Sealed burners
M Pro Dual Stacked Burner System
So perhaps my hack won't work if they aren't removable.
I found this video :>)
https://blog.yaleappliance.com/new-miele-hr1124-30-inch-professional-gas-range
We can not turn on stays locked ;we have an Miele induction cook top
https://www.coolblue.nl/en/advice/errors-miele-induction-cooktops.html
How do I unlock
my Miele cooktop
? Just under the lock light you should be able to press/hold with your thumb for about 5-15 seconds and it should reset. You may need to place your thumb directly over the lock light or just below it and hold it for that time.
Just under the lock light you should be able to press/hold with your thumb for about 5-15 seconds and it should reset. You may need to place your thumb directly over the lock light or just below it and hold it for that time. If this doesn't unlock when you do this then you have a problem with the control board.
Miele KM-493 induction stove. What does error E13 indicate?
- Error code E13 error showing on display
- What causes an E13, E 13 error code on the Induction Cooktop control panel?
- Error code 13 on Induction Cooktop control panel
Cause:
- Universal OFF key failure
Troubleshooting:
- If the controls are wet or water made contact with them, dry off the controls.
- Turn off then back on to reset.
- If the error persists, reset the unit at the circuit breaker.
- Turn the unit back on to see if the error code cleared.
Miele induction stovetop dE error?
Miele cooktop induction KM 6350, 6380, 6382, 6383 dE mode
How to switch off demonstration mode
Press ‘power’ button on front and ‘lock’ bottom at same time until you get p5 mode displaying ( it is in programming) mode.
Then press top left to ‘0’, bottom left panel to ‘0’, then press right bottom panel to 9, then press on ‘power’ button to save. This should take it off demonstration mode.
