20 Most Recent Frigidaire PLHS67EGSB Stainless Steel Side by Side Refrigerator Questions & Answers
Refrig and freezer working on and off for 2 weeks
have you gone here with the model # and cked out what the site says... https://www.repairclinic.com/?clearLs=true without a model # is hard to help.
1/1/2018 10:51:03 PM • Frigidaire... • Answered on Jan 01, 2018
2answers
Water smells from my side by side
Hello Maria, this is JK. I understand that you recently purchased a pre-owned refrigerator. Changing out the filter and the tubing were a great start to clean water. If you have not already, I would encourage you to run 10-12 glasses of water to freshen the supply and rinse out the tank. If you find that this odor and taste still persist, you may want to have the water tank replaced. Hope this helps!
1/4/2015 6:55:59 PM • Frigidaire... • Answered on Jan 04, 2015
Freezer defrost
If the unit is less than 10 years old going into defrost at least 3 times a day is totally normal and not harming anything.
3/2/2014 4:40:19 AM • Frigidaire... • Answered on Mar 02, 2014
Frigidaire PLHS67EGSB1, the digital guage to set the tempoearture keeps chaning. set it at 0, day later might read 16, one tap down and goes back to 0. Next day might read 8, same thing. What can c
Most likely the=> 241608401 Thermistor and the=> 241608501 Freezer Thermistor You will need to begin somewhere and with the symptoms you are having it brings the controls the regulate temperatures to the top of my list for what may be causing this. PLHS67EGSB1 Controls item 21 and 21A are the thermistors I am here should you have questions, Thanks, John Tripp Appliance 911 uploads>parent.mediatoolbar.onimageuploaded('error with image');
2/17/2014 1:38:26 PM • Frigidaire... • Answered on Feb 17, 2014
Fridgidaire PLHS67EGSB5 wont make ice
do you have the adjoining rod in the down position? and is the filter under the door clogged..
1/15/2014 3:43:21 AM • Frigidaire... • Answered on Jan 15, 2014
My frigidaire GSI26 is working
FREEZER FAN MOTOR MAY NEED REPLACED. THE EASIEST WAY IS TO TAKE OFF THE BACK PANEL IN FREEZER AND REMOVE THE FAN
MOTOR, TAKE IT TO THE NEAREST APPLIANCE PARTS STORE WITH YOUR MODEL NO.
EASY JOB.
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If
you need more help go here:
http://www.applianceaid.com/procedures.html
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
9/9/2011 2:20:44 AM • Frigidaire... • Answered on Sep 09, 2011
My refrigerator just won't run. We noticed that
Electrical: A 115 Volt, 60 Hz., AC only 15- or 20-
amp fused, grounded electrical supply is required.
It is recommended that a separate circuit serving
only your refrigerator be provided. Use an outlet
that cannot be turned off by a switch. Do not use
an extension cord
QUICK REFERENCE TO YOUR MANUAL
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=mfi2568&siteCd=MT_EN_US
COOLING
Dust on the condenser coils can cause overheating, observe safety precautions then clean coils. Switch off the unit before you clean them. If the problem persists, test the compressor for overheating. Overheating will cause many problems with cooling ability. Leave the unit unplugged for 3 hours and plug it in again. If it starts working, the compressor is probably overheating (Observe cautions with food going bad). A simple cause of the problem might also be that there is not enough airflow Lack of airflow is the number one cause of compressor problems and thus an owner purchasing another unit for hundreds of dollars when you can fix it for free.There should be at least several inches distance between the sides and walls/cupboards/ceiling.
Electrical
There is an in-line fuse mounted in the line supplying the power to the ice-maker. It is in the wire clipped to the side, change out this fuse asap. It is actually a 20-amp fused, associated with the grounded electrical supply.
PARTS
You may order parts very cheap from here
www.canadianappliance.ca/KBRS22KV.html
TIME TO CHANGE YOUR FILTER
While your on the back of the system, please check the filter. There is a filter in the back of the fridge in the upper right hand side. If you do not change it, it will slow down the frig and burn it out permanently.
1/25/2011 2:15:20 AM • Frigidaire... • Answered on Jan 25, 2011
FRIGIDAIRE
Here is a tip that will help you to get better results from your question on Fixya.
How to ask a question on FixYaheatman101
11/19/2010 5:13:45 AM • Frigidaire... • Answered on Nov 19, 2010
FIGIDAIRE MODEL PLHS67EGS/ 2006 IS NOT COOLING OR
Hi!!
Check fan in the freezer to see if it is working, if it is, check if compressor and fan on the back bottom of unit are working and make sure condenser coil is clean, use a vacuum with the small brush adapter, be gentle, the coils bend easily.
If all the mentioned items are working fine, the evaporator coil is frozen and do not let cool air flow. This is not uncommon if you open the freezer door too long or too often, among other things. Gather a couple of towels and place one on the bottom of the freezer and the other one in front of it. Unplug unit from wall, transfer all items to the fridge section, remove freezer back panel, ({where fan is), and use a heat gun or hair dryer to defrost evaporator coil.making sure the air ducts to the fridge are clear. Plug unit back and set temp. as usual for both, the fridge and the freezer, wait 24 hrs to re-adjust. If you need a parts diagram of your unit, please provide an email address to send it to, this site only allows us to send 150k max images.
If it happens again, have the defrost timer and heating element checked.
Good Luck!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
11/19/2010 1:57:08 AM • Frigidaire... • Answered on Nov 19, 2010
My freezer is at 60 and fridge is at 58 also water
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
10/17/2010 3:57:28 AM • Frigidaire... • Answered on Oct 17, 2010
I have replaced my Frigidaire water filter with a
the seal on the filter cover- is it cracked, pinched, broken or missing? if so, get a new seal. if it's leaking from the tubes going to it, tighten them with a crescent wrench.
9/24/2010 10:26:01 PM • Frigidaire... • Answered on Sep 24, 2010
Freezer is melting
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
5/27/2010 3:19:59 AM • Frigidaire... • Answered on May 27, 2010
Theice maker in my refrigerator makes thin shallow
that indicates it is not getting enough water inthe ice mold most icemakers have a water adjustment screw behind the cover if it cant be adjusted the inlet valve may need replacing
1/22/2010 11:11:48 PM • Frigidaire... • Answered on Jan 22, 2010
Frigidaire PLHS67EGSB Stainless Steel Side by Side Refrigerator Logo
Popular Tags
29 questions posted
Top Frigidaire Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
john h
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Frigidaire Refrigerators
Most Popular Question
refrig freezer working off 2 weeks
  • Refrigerators
