20 Most Recent
Sony CDX-GT210 CD Player Questions & Answers
My Sony CDX-GT210 has sound
Bill, did you ever figure your issue on your "no sound" problem? I'm having the exact same issue with a used car I bought that has this same stereo in it. CD plays and has sound, tuner shows its on but no sound. ????
I need a wiring diagram for this stereo
FOR 16-PIN HARNESS
Pin Number Wire Color Function
1 White Left Front (+)
2 Green Left Rear (+)
3 Violet Right Rear (+)
4 Grey Right Front (+)
5 Blue/White Amplifier Remote
6 Blue Antenna Remote
7 Red Accessory 12 Volts
8 Black Ground
9 White/Black Left Front (-)
10 Green/Black Left Rear (-)
11 Violet/Black Right Rear (-)
12 Grey/Black Right Front (-)
13 Sky Blue Telephone Mute
14 Orange/White Illumination
15 Not Used Not Used
16 Yellow Constant 12 Volts
FOR 9-PIN HARNESS
1 Not Used Not Used
2 Black Ground
3 Grey Right Positive
4 Grey/Black Right Negative
6 Red 12 Volt Switched
7 Yellow 12 Volt Constant
8 White Left Positive
9 White/Black Left Negative
MAY THIS HELP YOU
The ATT keeps switching on
It sounds like you have a bad switch. If you never use the att switch you can bypass the problem by removing the switch. Otherwise it should be replaced.
Sony CDX-GT210 Can't find the
Usually Reset button located underneath front panel, remove front panel and look at unit, hopefully you will see reset button, press it with some pointed thing like paper clip etc to reset the unit.
Thanks.
Sony cdxgt210 radio is not working
Yesterday i had to tosh mine and get a pioneer the guy told me that it's a common problem with this line of sony's. Its the tuner and it would have cost me 65 euro to get it fixed.
What color wire is the
I think you're asking for the switched/ignition wire which would be the red wire on the Sony harness. Also you could try the blue (remote/antenna) wire. The manual can be viewed/downloaded
here.
Hope this helps
Ray
Installing a sony cd/radio (CDX-GT222)
Sounds like a possible ground issue. Check your ground (very important). Also try running the red wire to a keyed source i.e. from fuse block. Then run the yellow to a constant 12v source i.e.battery.
