20 Most Recent
Acer Veriton 6900 PC Desktop Questions & Answers
How do I remove the optical drive from an
You may need to remove the front bezel before taking the drive from the bay. there are screws that latch the drive into place, and they are likely hitting the bezel on the way out. Most bezels pop off easily. You should consult Acer tech support for details.
Acer Elock problem
here is the elock guide
http://static.tigerdirect.ca/pdf/Acer_eLock-Management-For_Desktops.pdf it will shed some light on what is happening. You may be able to disable the elock service from
start -> run -> type in services.msc
Look for elock service by scrolling down to it. Right click properties,change the startup type to "disabled" and stop the service, on some elocks this is enought to stop it from working. but it depends on if they've changed it recently. post again here if you need furthur assistance.. Reagards.
Warning your chassis has been opened
Hi need help asap.
I opened my acer desk top box to clean dust out and now has warning chassis open.
I cant access the bios or anything else. Does someone have a suggestion????
Panicking
How do i install an ssd to replace hard drive
The drives will usually come with a utility to copy your old drive to the SSD and make the SSD the bootable drive. You just need to have both drives connected at the same time. Check for download instructions in the packaging with the drive or check the manufacturers website.
Desktop wont start up
Need more info here please. What kind of computer is there any beep. Try to unplug your computer then while it's unplug hit the power button. Then plug Back in see if this helps
Why blinking yellow light and green light infront of cpu
Check if the signal cable for the display is connected and whether there is any kink that may break a wire inside the cable. If the circuit for display inside the computer is broken, most of the time you would hear beeping when turning on the computer.
How can i reset my administration password if i
Use your windows disk and reset the password from there.
2. Boot into safe mode (using f8 at startup) and you will be logged into the built in admin account where you can change the other admin passwords.
3. Use the free Trinity Rescue Kit to recover the admin password.
