20 Most Recent Nostalgia Electrics SRCD820 Turntable Questions & Answers
Gee, Google found it and a source. "Sylvania SRCD 820 needle".
Why waste time putting this on Fixya?
http://www.lpgear.com/Merchant2/merchant.mvc?Screen=CTGY&Store_Code=LG&Category_Code=SYLVANIASTY
Nostalgia... | Answered on Jun 19, 2011
release the orange case from the back and slide forewards.Note,use athin knife blade to ease the case sides 2no. from holding points on head.BUT THERE MUST BE A BETTER WAY???.
Nostalgia... | Answered on Nov 26, 2009
Free instructions for one model yogurella. You can respond with more information to add to your question using the Comment menu. http://www.manualsdir.com/manuals/20456/ariete-yogurella-metal-620.html?page=13
Audio Players &... | Answered Yesterday
Is your PC Bluetooth-enabled ? If not, you will have to buy a USB Bluetooth adapter for your PC.
Try Googling (denon)(pma 355uk)(manual) without parens.
I believe this unit employs an optical sensor to detect tape end.
Clean this off to. It looks like a transparent post positioned along the tape path. Reset the counter to zero and fast forward tape to end. Rewind, and try to play tape as normal
Hi, there
Since your unit has a CD player, the problem with both the turntable and cassette deck is probably due to the rubber belts that turn both mechanisms losing elasticity or have broken over time (or in the worst case scenario, turned to goo). I don't know your model manufacturer, but turntables often have a clip, or some sort of apparatus, that you can remove to lift the turntable platter up and off. If you can do that, you will be able to see what shape the turntable belt is in. For the cassette deck, more intricate disassembly is required. Replacement belts for both can often be found on eBay or other online sources.I found a video for an ion turntable that might have a similar belt system.
Audio Players &... | Answered 2 days ago
Hello Billy, obviously your STR-K502P, has problems in the main power supply, control you have to remove the cover and look for a fuse indicated as; F901 FUSE (6.3Amp / 125V) and fix it is burned, if so, before replacing it, you would have to get a lamp holder and an incandescent lamp of 200 watts, the old lamps that bring filament, and connect the cables of the holder lamp to the ends of the fuse holder, the lamp replaces the fuse (serial lamp), you connect the STR-K502P to the power network and turn it on, if the lamp turns on completely and stays that way, it is very likely that there are components damaged and are generating a short circuit, in this case I suggest you look for a specialized technical service
If, on the other hand, the lamp is turned on and off or the intensity of the initial flash is reduced, this would give a guideline that there is possibly no short circuit, you can test the operation of the STR-K502P in this situation, if you can hear it, then replace it the fuse, its value is 6.3 Ampere / 125Volts
Once this is done, do not use the STR-K502P, without first checking all the cables and connections of the speakers, corroborating that you do not have any short circuit in them
I hope you can solve it
Greetings Franco Dosil
Hola Billy, evidentemente tu STR-K502P, tiene problemas en la fuente de alimentaci?n principal,controla tienes que sacar la tapa y buscar un fusible indicado como; F901 FUSE de (6.3Amp/125V) y f?jate se esta quemado, de ser as?, antes de reemplazarlo, tendr?as que conseguir un porta lamparas y una lampara incandescente de 200 watts, las viejas lamparas que traen filamento, y conectar los cables del porta lampara a los extremos del porta fusible, la lampara reemplaza al fusible (lampara serie), conectas el STR-K502P a la red de energ?a y lo enciendes, si la lampara se prende por completo y se queda as?, es muy probable que haya componentes da?ados y est?n generando un cortocircuito, en este caso te sugiero que busques un servicio t?cnico especializado
Si por el contrario, la lampara se prende y se apaga o baja la intensidad del encendido inicial, esto dar?a pauta que posiblemente no hay corto circuito, puedes probar en esta situaci?n el funcionamiento del STR-K502P, si logras que puedas escucharlo, entonces reemplaza el fusible, su valor es 6,3 Amper/ 125Volts
Hecho esto, no utilices el STR-K502P, sin antes controlar todos los cables y conexiones de los parlantes, corroborando que no tengas alg?n cortocircuito en ellos
Espero que lo puedas resolver
Saludos Franco Dosil
Lorraine McKellar wants answers to this question
Hi Lorraine, I sent you the link so you can get the DVB-T202 user manual
Hola Lorraine, te envio el link para que puedas obtener el manual de usuario del DVB-T202
https://data2.manualslib.com/pdf3/79/7820/781968-august/dvbt202.pdf?25f00993f17422491b49e230e03de502&take=binary
2 questions posted
Top Nostalgia Electrics Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Nostalgia Electrics Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Nostalgia Electrics Audio Players & Recorders
Most Popular Question
just need know name
  • Audio Players & Recorders
