20 Most Recent Denon DVD-557 DVD Player Questions & Answers
2010 is far from NEW like 7 years
Denon DVD-557... | Answered on Jun 03, 2017
No.Must read ur owner manual,check if ur dvd player is a region free DVD player,than can put it in Auto setting,If not,must have to buy a new DVD player that work on PAL,the region u live in.
Denon DVD-557... | Answered on Dec 15, 2010
sounds like its stoping during layer switch, if the player is old its needs to be cleaned. its best to clean it once every 20hrs or so. if you do not have a disk cleaner you should go buy one first. if the player is new return it and get the best dvd player you can buy for any amount the toshiba xde. this player is phenomenal, the best you will be amazed. no i dont work for toshiba but ever since they started making hd dvd players(i know they stopped)there players have become the best. trust me if you dont think so just return it. no harm done. if you want a blu-ray get ps3 I dont like them either but i have to admit after buying (for movies only)my third blu-ray player it is by far the best one. almost as good as the toshiba on standard dvd playback but not quite. good luck.
Denon Televison... | Answered on Apr 17, 2019
Verify that the disc turns, put it in the tray, observe the position, enter it, wait for the indication of "No Disc" and remove the disc, if it is in the same place, apparently, it would have problems in the disc engine
Another way to check if the engine works, play an audio CD, if you read it, apparently the engine, it would not be the cause of the failure
If I notice that I turn, I could have dirt problems in the lens of the reader, proceed to clean it with a cotton swab and if you do not know how to do it, contact a technical service
Another option, it is possible that your reader is under power to read the DVD
Verifique que el disco gire, p?ngalo en la bandeja, observe la posici?n, ingreselo, espere a la indicaci?n de "No Disc" y saque el disco, si esta en el mismo lugar, aparentemente , tendr?a problemas en el motor del disco
Otra forma de chequear si el motor funciona, reproduzca un CD de audio, si lo lee, aparentemente el motor, no seria el causante de la falla
Si observo que giro, podr?a tener problemas de suciedad en el lente del lector, proceda a limpiarlo con un hisopo de algod?n y si no sabe como hacerlo, dir?jase a un servicio t?cnico
Otra opci?n, es posible que su lector esta bajo de potencia para leer los DVD
Denon Televison... | Answered on Apr 14, 2019
How do I reset my Denon remote?
All the settings are restored to their defaults. Press and hold RC SETUP for more than 3 seconds. "SETUP" and indicator flashes twice on the remote control unit. Use to display "RESET" on the remote control unit and press ENTER
Denon Televison... | Answered on Mar 08, 2019
If you have the Audyssey set up mic, plug it in and follow the on screen instructions. Or try installing the Denon AVR remote app.
Denon Televison... | Answered on Dec 26, 2018
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
https://homenol.blogspot.com/
https://electronicshelponline.blogspot.com/ Search the site by type in the "brand name" to your device, [Exclude the model number] in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Denon Televison... | Answered on Feb 17, 2018
Denon DVD-557 DVD Player Logo
6 questions posted
Top Denon Televison & Video Experts
 Grubhead
Grubhead
Darial Jr Lasaria
Darial Jr Lasaria
Are you a Denon Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Denon Televison & Video
Most Popular Question
denon dbp 2010 ci freeze up
  • Televison & Video
