20 Most Recent
Amana LWA40A Questions & Answers
Need to know how to remove agitator on my
The agitator will just pop off with enough working with it. There are no screws that hold it in place. Just some slight prying and some wiggling and it will come off. They are on there pretty solid so just work with it
6/1/2010 2:57:09 PM •
Amana LWA40A
Answered
on Jun 01, 2010
Amana washer LWA50AW
I had the same issue last year on y lwa50aw. It is the timer. Get the speedqueen version it is about $50 -$80 and aboyt 15 minutes to replace.
4/26/2010 8:37:14 PM •
Amana LWA40A
Answered
on Apr 26, 2010
What does the code nd stand for?
this is a no drain error or slow drain issue you need to check for anything that would or is restricting the water from draining out of the tub.
if the water will not srin then you can use a wet dry shop vac and attach it to the end of the drain hose to remove the water.
then check all your hose to and from the drain pump
4/13/2010 3:33:36 AM •
Amana LWA40A
Answered
on Apr 13, 2010
Water leak. noticing water under the machine and
without really looking at it i would have to say it Sounds like water seal gone in drum. If back of drum at the bottom is wet with black or dark run stains this is the problem.
Good luck
John
9/3/2009 9:17:38 PM •
Amana LWA40A
Answered
on Sep 03, 2009
Remove front panal
Hi, there are two screws at the bottom of the front panel. THis should release the panel by ulling the bottom toward you. Let me know if I can assist you further.
Thanks
Vic
5/16/2009 3:22:56 AM •
Amana LWA40A
Answered
on May 16, 2009
Amana LWA50AW Washer Leaks!
you need to get the front off... grap a light and get down and look inside to find out whats leaking... with out looking its just guessing
check all water hose connections, water pump, and main seal where transmission goes thu drum
6/21/2008 1:32:11 AM •
Amana LWA40A
Answered
on Jun 21, 2008
Lws34aw
Remove the front panel, two screws on bottom. On the bottom of the motor is a white colored pump, if the water is coming from there you need to replace the pump. you can find this part on line, just google Amana washer parts.
Let me know ifyou have any more questions.
5/25/2008 12:05:17 PM •
Amana LWA40A
Answered
on May 25, 2008
Leaking
Take front of washer .. get light and look for leak and listen to find out where noise is comeing from
12/9/2007 5:05:43 PM •
Amana LWA40A
Answered
on Dec 09, 2007
Everything works but machine won't agitate
The pull at the bottom of transmission should turn both ways.. one way for spin the other way for agitate... if transmission turns both ways means not locked up and probley bad motor..
9/5/2007 3:11:46 AM •
Amana LWA40A
Answered
on Sep 05, 2007
