20 Most Recent
Amana ALW895 Top Load Washer Questions & Answers
My dryer squeaks
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Install belt on Amana top load washing machine
Use the correct sized belt!!
Loosen the Motor mounting Bolts. ( Do not take it off ) Now the motor assembly can be moved towards the opposite large pulley.
Replace the belt in this position and slide the motor to it's original position. You adjust it in such away so that, the belt is not too tight or loose!
Will spin but not agitate LWA40Aw2
Hi, it sound likes a belt. Some amana washers take 2 belts,1 for the spin,and 1 for the agitate. or some models spin rite of motor,and a belt for agitate. hope this helps. :)
Washing machine squeak
Same squeak on spin -LW8203 shortly before that she ran an off balance load and now wonders why it squeaks..
Amana washer. Why is it acting up?
Question edited for clarity, 'Amanda' to 'Amana'.
Question moved to maker category.
It is sensing, and that you have something that needs a 'Delicate' setting, or a 'Woollens' setting. It provides water and very little agitation that might damage or stretch the clothes. Read the manual.
Google
Amana (model) manual
I have an Amana Tandem 7300 Front Load Washing Machine.
Fiona, could it be that your'e using Liquid color-safe bleach as it is thicker than chlorine bleach and will not dispense properly from the chlorine bleach dispenser?
And did you Remove the inserts from the drawer. The inserts are the detergent selector and covers of the softener and bleach dispenser.. and clean and replace them?
Tis really hard not being there and being able to see the unit.
But thought I'd give you these suggestions.
Best to you.
