20 Most Recent Amana DLW330RA Top Load Washer Questions & Answers
We can hear water running but it's not filling the wash tub. There is no water leaking anywhere.
check that the tap is fully opened , the filter in the end of the hose is not blocked check that the tap washer is not jammed off in the tap as they can expand and not move up to let water in check water inlet solenoid is functional
8/23/2015 2:04:19 AM • Amana DLW330RA... • Answered on Aug 23, 2015
Where is cold water screen located?
in the water inlet valve hoses
4/11/2015 9:32:34 PM • Amana DLW330RA... • Answered on Apr 11, 2015
0answers
Belt replacement
belt goes on the bottom of dryer. look up your model on internet on replacing belt . its pretty easy. if old belt is still on make a diagram of how belt goes on, also take a pic.
1/30/2014 11:38:27 PM • Amana DLW330RA... • Answered on Jan 30, 2014
Cold water keeps running
what is your model number is then we can get started then okay
1/29/2013 3:41:26 PM • Amana DLW330RA... • Answered on Jan 29, 2013
Clicking sound on spin cycle
see this causes and fix it. God bless youLevel If it is shaking and not sitting flat ( should have no rock corner to corner) check the leveling legs. Make sure to tighten up the locknut after adjusting. Timer Sometimes a Timer will start making noises before they fail. I would highly suggest replacing the timer as soon as the noise develops. This can cause problems with your motor and other components if left alone. This is easy to identify just listen up near the console when running. Transmission The transmission does not usually fail but to check this on a direct drive remove the motor and rotate the inner tub and listen for noises it should be quiet. If not the transmission is expensive and you will need to evaluate wether it is worth repairing. Motor Coupler On direct drive machines this is a common failure and can be very noisy. To check and replace the motor coupler watch the video. Motor You will need to disassemble the washer to listen to the motor running. If the motor is noisy it will need replacing. On direct drive models check the motor coupler first. Suspension Rods The Suspension Rods support the tub under the cabinet on some models. The washer must be disassembled to access. These usually do not fail. On direct drive types there will be springs instead of suspension rods. Either usually fails but can from being overloaded. Drain Pump The drain pump can be the cause of noise. On belt drive types remove the belt and rotate the pump pulley it should spin freely and make no noise. If it is noisy replace. If it does not spin freely remove and inspect for obstructions if none found replace the pump. Check the impeller on the pump it should be tight and spin freely. On direct drive types remove the pump and inspect or replace.9_29_2012_11_23_52_am.jpg
9/29/2012 11:24:08 AM • Amana DLW330RA... • Answered on Sep 29, 2012
MACHINE FILLS UP WITH TOO MUCH WATER WHEN FILLING UP
Possible that the water level controller is faulty and so needs to be checked as the pressure switch if defective will not work and so the inlet valve will not be cut off. check this link for replacinmg inlet valve: Inlet valve
6/26/2012 11:17:39 AM • Amana DLW330RA... • Answered on Jun 26, 2012
WATER WON'T CUT OFF WHILE FILLING THE MACHINE
This is due to the fact that the INLET valve is not working.Now this can be due to either the failure of the valve - keeps open - or failure of the control from the program controller unit. You need to use a multimeter to check the voltage to the inlet valve coil to confirm this. Also make sure that the valve is not choked and so is kept open.
6/26/2012 10:07:08 AM • Amana DLW330RA... • Answered on Jun 26, 2012
Cold water not coming in
Possible that the cold water inlet valve is faulty and so the voltage to the inlet valve must be checked. If there is no voltage then the controller unit is faulty, if not the inlet valve is faulty.http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
3/15/2012 5:50:08 AM • Amana DLW330RA... • Answered on Mar 15, 2012
When washer gets to spin cycle it will spin for 3 second then cut off, A few minutes later I hear a click inside the washing machine and it will try again
If there is smell that keeps on increasing then you must shut down the washer and remove power. Check on the motor , the capacitor to the motor and the main control panel. Since smell was noticed there can be ccomponents and so take care not to burn you fingers when you touch any part. Once this is identified you can remove and repace. if the heat was noticed on the motor,check for free movement of the spindle or it can be due to possible heavy load. Also check for inlet and drain valve pump to be faulty and have burning off the coils.
11/10/2011 3:38:28 AM • Amana DLW330RA... • Answered on Nov 10, 2011
Hi, I've just bought Yamaha
Unfortunately you are not likely to obtain an answer from the WASHING MACHINE forum- except for this one ;-0(
I would try re-posting if I were you.
Good luck anyway!
John C
PS As it happens I bought a second hand guitar which also had a nut missing from one of the controls. Eventually managed to find a replacement from the 'local' music shop ;-0)
3/27/2011 2:29:56 PM • Amana DLW330RA... • Answered on Mar 27, 2011
Spin cycle doesnt work
Hi.
Here a general troubleshooting for no spin problems : If you have no spin there may be different reasons behind the problem. Before advancing to
With top loaders you need to add to the list problems related to motor and transmission. Such problems will be at the end of the troubleshooting list, right before inspecting the electronic control.
With this model the more common failures are concerning drain system, lid switch and pressure switch.
Here parts.
Regards.
Ginko.
1/12/2011 5:15:14 PM • Amana DLW330RA... • Answered on Jan 12, 2011
Ok i took the screws out of the pump and am trying
It is usually a little seized on from rust on the shaft, use i pry bar to remove it.
12/16/2010 2:55:47 AM • Amana DLW330RA... • Answered on Dec 16, 2010
How do i replace the belt on this model?
Oh this is a fun one, You will need to remove the drain pump in order to get the belt in place, the pump screws are a size T20 Torx bit. you will need a skinny extension to reach the screws. If you need anymore help feel free to reply.
Please rate my solution if it was helpful to you.
Thanks, Repairman45.
12/16/2010 1:54:56 AM • Amana DLW330RA... • Answered on Dec 16, 2010
How do I replace the
Please check the below website
http://www.searspartsdirect.com/partsdirect/part-model/Amana-Parts/Washer-Parts/Model-DLW330RAW/1268/0153200/M0603029/00008?blt=06&prst=&shdMod=
In this website they have given all the part number and exploded view of your model machine.So that you can order the spin belt accordingly.
Thank You
10/6/2010 3:53:11 AM • Amana DLW330RA... • Answered on Oct 06, 2010
Amana DLW330RA Top Load Washer Logo
65 questions posted
Top Amana Washing Machines Experts
Virgil Watts
ZJ Limited
ZJ Limited
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Amana Washing Machines
Most Popular Question
belt replacement
  • Washing Machines
