20 Most Recent Amana NAV5800AW Top Load Washer Questions & Answers
I have an Amana NAV5800AW.
you could have small item stuckin hole of the washer basket so look an see if there anything in small hole ok
12/18/2017 6:51:00 PM • Amana NAV5800AW... • Answered on Dec 18, 2017
My amana top loading washer
Your pump can be clogged as well. Here is a generic video that shows how to unclog a drain pump.
11/21/2017 3:27:22 PM • Amana NAV5800AW... • Answered on Nov 21, 2017
Amana washing machine dosent spin
Maybe door switch? Hear any humming? Belt might be broke. Service Manual If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
8/4/2012 8:51:18 PM • Amana NAV5800AW... • Answered on Aug 04, 2012
The washer vibrates in the wash and spin cycle .
Try checking for the shipping screws, did you remove them? They are there to prevent the drum moving during transport but if left in the whole machine will try to jump about.
6/10/2011 1:18:54 AM • Amana NAV5800AW... • Answered on Jun 10, 2011
Water on the floor & very noisy spin. 6yrs
The main bearing seal let go and that is the cause for the noise and water on your floor. The repair is costly, around $350 for repair.
3/1/2011 5:19:22 PM • Amana NAV5800AW... • Answered on Mar 01, 2011
I have an Amama NAV5800AW
The noise you are hearing is the main tub bearing. Water has been leaking past the seal and into the bearing causing it to rust.There is no lubrication on the bearing anymore and you are hearing the metal on metal grinding. You are looking at a costly repair of about $350. I hope this helps you out.
3/1/2011 12:28:16 AM • Amana NAV5800AW... • Answered on Mar 01, 2011
Hi When spin drying or any fast spin cycle it has
sounds like main tub bearings are gone ..turn the drum by hand if it rumbles its bearing dont use it ... this is not a good job to do.
2/27/2011 6:46:20 PM • Amana NAV5800AW... • Answered on Feb 27, 2011
Washing machinr not going into spin cycle, also
If the machine works up to that point then the timer is at fault.
2/26/2011 11:59:49 PM • Amana NAV5800AW... • Answered on Feb 26, 2011
Burned smell coming from washer
Might be a locked up pump or maybe a thrust washer gone out? MORE here If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
1/15/2011 2:03:26 AM • Amana NAV5800AW... • Answered on Jan 15, 2011
Here is the fix for "soapy" problem. Follow this link to part.
12/1/2010 2:03:19 AM • Amana NAV5800AW... • Answered on Dec 01, 2010
2answers
The washer does not initiate a drain of either
the motor/ trans / pump / belt / ect yes they are all fine the problem is the timer . the timer stopes the motor after the wash and starts it in the other dir to spin and drain . but this is not happing . so the timer is at fault . pt # 27001088 100.99 hope this helped mm feed back pls
11/16/2010 11:26:15 AM • Amana NAV5800AW... • Answered on Nov 16, 2010
I have a 7 year old Amana NAV5800AW. It just
Is it spinning while making the noise?<br /> <br /> <a href="mailto:[email protected]">[email protected]</a><br />
9/4/2010 2:27:41 PM • Amana NAV5800AW... • Answered on Sep 04, 2010
Wahing machine won't do anything
when in some of your wash cycles, try wiggling the timer knob back and forth. sometimes if the timer is going bad the motor will come to life for a split second. if this is the case you need a new timer. if it is completely dead no matter what, you most likely have a bad motor but there is still a chance that there is a bad timer. the odds just increase that it is a bad motor.
10/10/2009 7:08:31 PM • Amana NAV5800AW... • Answered on Oct 10, 2009
I just replaced the water valve inside the machine
u can connect one of them on the hot water valve and turn it on with temperature
if it works then u got the right connection if it doesn't then just swich them on
this is not dangerous
6/5/2009 10:09:33 PM • Amana NAV5800AW... • Answered on Jun 05, 2009
Amana washing machine lid is locked and it's like it's not getting power
If your Amana washing machine lid is locked and it seems like it's not getting power, there are several steps you can take to troubleshoot the issue. Follow these steps to identify and potentially resolve the problem:
3/7/2024 7:01:50 AM • Amana Washing... • Answered on Mar 07, 2024
Will an Amana washing machine, power up without the inlet valve hooked up
Probably but not advised.
3/6/2024 8:35:39 AM • Amana Washing... • Answered on Mar 06, 2024
Amana washer. Why is it acting up?
Question edited for clarity, 'Amanda' to 'Amana'. Question moved to maker category. It is sensing, and that you have something that needs a 'Delicate' setting, or a 'Woollens' setting. It provides water and very little agitation that might damage or stretch the clothes. Read the manual. Google Amana (model) manual ..
10/20/2023 4:58:36 PM • Amana Washing... • Answered on Oct 20, 2023
Amana NAV5800AW Top Load Washer Logo
26 questions posted
Top Amana Washing Machines Experts
Virgil Watts
ZJ Limited
ZJ Limited
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Amana Washing Machines
Most Popular Question
washer not initiate drain either
  • Washing Machines
