20 Most Recent Amana NAV5800A Top Load Washer Questions & Answers
Reduce the actuator speed to slowest/delicate speed. Good luck
Amana NAV5800A... | Answered on Jan 10, 2018
exspensive but u can find much cheaper on ebay
Amana NAV5800A... | Answered on Apr 11, 2015
no it will spin and agitate but be careful if u have children the door switch is a safety feature to keep it from spiining when lid is open
The motor sounds like it is overloading and kicking out. Most likely cause: binding brake pads.
Amana NAV5800A... | Answered on Sep 13, 2013
The water drained out ok? If yes, the timer is telling the motor to reverse and run in the drain spin direction and it is likely ok. If the draining is slow the clothes could come out wet, if the belt is cracked or streatched the clothes could come out wet. If the motor is not running through the entire spin/drain mode the timer could be at fault.
Will Not Spin
• Check for unbalanced load.
• Check for broken or slipping belt.
• Does the house drain system accept water from
machine?
• Check for blocked drain hose.
• Check for binding tub seal.
• Check for partial engagement of brake assembly.
• Check for obstruction between tubs.
• Check for broken impeller on pump.
Amana NAV5800A... | Answered on Jan 02, 2012
Amana NAV5800A Top Load Washer Logo
70 questions posted
Top Amana Washing Machines Experts
Mike
Gerry Harvey
Gerry Harvey
Virgil Watts
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Amana Washing Machines
Most Popular Question
drain or spin
  • Washing Machines
