20 Most Recent Maytag EPIC MFW9600S Questions & Answers
16answers
SUDS and F02 error codes on Maytag Washer
If it's not draining properly and shows this F02 Code there may be a simple solution. Take the bottom front panel off (it has 3 screws.) There will be an off white circular plastic thing there. Resembles the top to a cannister. Twist it off. There will be a good bit of water if it hasn't drained properly. I put a cookie sheet under it to catch most of the water. Once you completely unscrew the top off hopefully your problem will be right there. Unbelievable...we found 2 socks, a glove, a bead, coins and don't ask me but there was a nail in there as well. I was so happy that we didn't need to pay a repair man.
10/12/2017 9:29:51 PM • Maytag EPIC... • Answered on Oct 12, 2017
5answers
Maytag front load washer mfw9600sq1 fh error after
Hi
Thanks for using FixYa.
If after 30 seconds the control does not detect water entering machine, the valves will be turned off and the error code will be displayed.
OR
If the control has turned the water valves on, and after 8 minutes, the flow sensor has detected
10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off, and the error code will flash. Press PAUSE/CANCEL twice to clear the display.
This error occurs usually if there is no water in the unit:
- Make sure that both valves at the water source(s) are turned on all the way.
- Check for plugged or kinked inlet hoses or plugged screens in the inlet valves.
- Verify inlet valve operation.
• If there is water in the unit:
- Verify drain pump operation.
- Verify that the pressure switch hose is in good condition and properly connected to tub and pressure switch.
1. Verify there is not a siphon problem.
2. Unplug washer or disconnect power.
3. Verify wire harness connections to inlet valves, pressure switch, drain pump, flow meter, and Central Control Unit (CCU).
4. Check all hoses for possible leaks.
5. Plug in washer or reconnect power.
6. Verify pressure switch operation.
7. Verify flow meter operation by blowing air through the part and measuring the resistance.
8. Verify CCU operation by running a Diagnostic test or any cycle
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
3/5/2017 5:19:18 AM • Maytag EPIC... • Answered on Mar 05, 2017
No alarm only the door close after i have flash light and dont start
probly door inter lock
4/26/2015 7:54:28 PM • Maytag EPIC... • Answered on Apr 26, 2015
Control lock stays on
Try holding for 3-5 seconds should unlock controls.
1/24/2014 4:25:50 AM • Maytag EPIC... • Answered on Jan 24, 2014
I have a problem with a f02 error
The washer is not finishing the cicle and is showing error f02
8/18/2013 6:48:28 PM • Maytag EPIC... • Answered on Aug 18, 2013
Suds and F02 Error codes.
You did all the right thing, now it could be the control panel
4/13/2013 3:48:46 AM • Maytag EPIC... • Answered on Apr 13, 2013
0answers
Flases f 21 code worked
I looked at your tech sheet. As you already know the F-21 on your machine has to do with touchpad not communicating with control. F21 F 22 CCU /touchpad/LED assembly unable to transmit/receive data to/from the CCU central control unit
Possible causes/procedure:
1. Check the touch-pad/LED assembly by selecting different
cycles and changing the modifiers and options available to
confirm the touch-pad/LED is responding.
3. Check wire harness connections to the
touch-pad/LED assembly and Central Control Unit (CCU).
If you have a new touchpad installed and the harness is fine then the control must be bad. If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
4/1/2011 3:45:55 PM • Maytag EPIC... • Answered on Apr 01, 2011
0answers
2answers
I have a Maytag front
Is it making the noise with the belt removed ?? If so it is the pump has an obstruction in it most likely. As for the bearing it is not an easy job . The whole drum assembly must be removed from the case and separated.
12/8/2010 4:23:42 AM • Maytag EPIC... • Answered on Dec 08, 2010
3answers
MAYTAG EPIC FRONTLOAD WASHER NOT DRAINING
The filter is in the front on this one. Under the door, there is another panel. There are 3 screws that a 1/4" nut driver takes off pretty easily. Get a bowl and bucket. There is a white screw cap that you should easily see. Open it slowly with the bowl underneath. Close it again when the bowl is filled and dump the bowl into the bucket. Repeat until no more water comes out then unscrew it completely. Clean out the trap and replace. There is a stop that prevents you from overtightening. See if that works. A six dollar nutdriver is easier and cheaper than any repairman.
12/8/2010 3:38:13 AM • Maytag EPIC... • Answered on Dec 08, 2010
My epic washer will not spin. Does this have a
Yes remove top and look down the back . You will see the pulley and the belt should go from there to the motor(flat serpentine type belt).
11/18/2010 10:23:07 PM • Maytag EPIC... • Answered on Nov 18, 2010
Maytag epic front loading washer i'm getting an
FH error indicates that either you have no water coming into the washer, or very little water. Since you can see it filling, the error indicates low flow. A flow meter
in the unit detects if 10.5 gallons fills the tub within 8 minutes; yours must not be. This will turn off the inlet valves and the error code will be displayed. Check the following:
- Make sure you don't have a siphoning problem. This occurs when there is no air gap for the drain line at the standpipe. The standpipe is the drain pipe at the wall where the washer drain line is placed. With no air gap, a vacuum is created, and water will begin to drain from the wash tub prematurely. To prevent this from occurring, follow this advice:
•The standpipe should be 2 inches in diameter to allow a sufficient air gap between the top of the standpipe and the drain hose.
•The standpipe should be a minimum of 34" from the floor, and should not exceed 72 inches in height.
•DO NOT seal the top of the standpipe. Many consumers seal the standpipe in the belief that this will prevent overflows, or get rid of drain odors. This often creates more problems than solutions.
•DO NOT place the drain hose too far down into the pipe. Water stays in the drain trap area of the standpipe. If the end of the drain hose rests in this area, no air gap is created, and this can also cause siphoning. 4 to 6 inches is sufficient.
•The drain hose length must not exceed 10 feet in length. Excessive drain hose length can cause drain problems and back wash.
- Verify Drain Pump operation. Unplug the washer and take the lower panel under the door off by removing the three screws under the bottom edge. With the screws removed, the panel should drop down then come off. If it sticks, tap either side and it should come free. The pump is located directly under the wash tub in the front of the washer. Verify the electrical connections are good and that the pump is running. Open the pump access and remove, once you have all the water drained. Check the drain pump for foreign objects and debris. Check the pump impeller and make sure there's nothing caught in it. Items as small as toothpicks or cotton swabs have been known to stop this pump from working.
- Verify Flow meter operation and that the Pressure Switch hoses are intact and connected properly. Remove the three screws in the top panel along the back of the washer. With the screws removed, the panel should slide back, then, lift off. The flowmeter will be located on the left-hand side of the washer (facing from the front) between the inlet valve and dispenser. It's a small white plastic device with hoses attached. The pressure switch is located on the right-hand side of the washer in the rear. It is a round plastic device with electrical connections and a hose attached. There should be a tech sheet directly behind the panel or attached to one of the interior cabinet walls. Please refer to this sheet to learn how to perform diagnostics, how to locate the components mentioned, and the specific measurements required in determining if the components are good or bad.
"F/H" indicates that either you have no water coming into the washer, or very little water.
If you have NO water coming into the wash tub after 30 seconds the error code is displayed. Check the following:
- Inlet water valve may be clogged. Clean inlet screens if necessary.
- Make sure water taps are on.
- Check inlet hoses for kinks or clogs.
If you HAVE water filling the wash tub, and after 8 minutes, 10.5 gallons of water has been detected by the flowmeter, but there has not been a detected a Pressure Switch trip, the inlet valves are turned off and the error code is displayed. Check the following:
- Make sure you don't have a siphoning problem. Click the following link for instructions: http://www.fixya.com/support/r587481-prevent_washer_siphoning
- Verify Flowmeter operation.
- Verify the Pressure Switch hoses are intact and connected properly.
To access the Drain Pump - UNPLUG the washer and take the lower panel under the door off by removing the three screws under the bottom edge. HINT: Propping the front feet of the washer up can make access much easier. I use a couple small blocks of wood. With the screws removed, the panel should drop down then come off. If it sticks, tap either side and it should come free. The pump is located directly under the wash tub in the front of the washer. Verify the electrical connections are good and that the pump is running. If not, click on the following link to check the pump for obstructions:
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
To access the Flowmeter and Pressure Switch - remove the three screws in the top panel along the back of the washer. With the screws removed, the panel should slide back, then, lift off. The flowmeter will be located on the left-hand side of the washer (facing from the front) between the inlet valve and dispenser. It's a small white plastic device with hoses attached. The pressure switch is located on the right-hand side of the washer in the rear. It is a round plastic device with electrical connections and a hose attached.
There should be a tech sheet directly behind the panel or attached to one of the interior cabinet walls. Please refer to this sheet to learn how to perform diagnostics, how to locate the components mentioned, and the specific measurements required determining if the components are good or bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
9/18/2010 10:21:38 PM • Maytag EPIC... • Answered on Sep 18, 2010
My Maytag MFW9600 front-loader makes
You will need to clean your washer out with this cleaner... The detergent and slime between the tubs mildew and a mold grows. Follow the instructions on the bag and use all 3 tabs to start. You need to change to a good detergent. Use a detergent with oxyclean or some type of oxgenated ingredeient.
You can find this cleaner at HomeDepot or Lowes
http://www.affresh.com/
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
9/10/2010 6:11:39 AM • Maytag EPIC... • Answered on Sep 10, 2010
EPIC MFW9600S F02 Error Code before cycle ends
The 3 screws come at the toe panel in front of the machine. You have to prop up the machine to have access to the screws, they come just underneath the panel. Its kinda of fashionable to place them there i guess, but that's it. On unscrewing the panel slides down & towards you. The rest of the matter you know by the posts.
6/17/2010 10:49:12 AM • Maytag EPIC... • Answered on Jun 17, 2010
Code F 02 draining problem. pipe not kinked or plugged
you may need to check the drain hoses that lead to the drain pump and look for any kind of restrictions,or some thing stopping the impellar wheel from turning in order to drain the water
6/5/2010 2:39:59 AM • Maytag EPIC... • Answered on Jun 05, 2010
My washer will not spin, when it gets to the point
f what?
1/31/2010 4:04:19 AM • Maytag EPIC... • Answered on Jan 31, 2010
Maytag EPIC MFW9600S Logo
54 questions posted
Top Maytag Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ZJ Limited
ZJ Limited
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Maytag Washing Machines
Most Popular Question
problem f02 error
  • Washing Machines
