20 Most Recent Dual XDM6830 CD Player Questions & Answers
this sounds like a wire has cum loose or ur cd player sensor has been damaged
Dual XDM6830 CD... | Answered on Mar 20, 2008
Hi Ant81,
You should only have the Blue wire from the Dual connected the REmote terminal on the Jensen Amp. The Audio cables are the only other wires that connect from the Dual to the Jensen Amp.
Dual XDM6830 CD... | Answered on Nov 26, 2007
Hi. SOunds like another case of power problems. Your deck has 2 power wires. One is yellow th eother is red. One is constant 12 volt battery power, the other is a switched 12 volt power, only has power with the ignition key on or on accesory. Get yourself a test light. I almost bet you do not have the constant 12 volt power to the deck, therefore your deck cannot hold its presets...
Dual XDM6830 CD... | Answered on Oct 26, 2007
Check all wiring/connections, fuses, etc. and don't forget the one on the back of the deck itself!
Dual Car Audio &... | Answered on Mar 19, 2019
YOU MIGHT TURN YOUR HEAD LIGHTS OFF
Dual Car Audio &... | Answered on Mar 10, 2019
What ohms are the voice coils, and what ohm rating is the amplifier you are hooking it to rated at?
Dual Car Audio &... | Answered on Feb 04, 2019
Hi there, in reality it does not work that way. The proper way is to contact the company that makes it and become a authorized service and repair person with the company which often inn wolves you paying for it, next after approved you need to buy the access to schematics from the company. Alternatively you can ask you question to get a better answer. You should also post pictures and picture of the circuit board where it connect, list you capabilities so I know what instructions to give, be ready to use a multimeter or a volt o meter.good luck https://www.6ya.com/mr.mike
Dual Car Audio &... | Answered on Jan 31, 2019
I have a Ford F-150 2001 and I'm trying to install xDVD8181 in it and I bought the accessorie for it from wall Mart and I have power to the radio but no sound what do I do
Dual Car Audio &... | Answered on Jan 29, 2019
http://www.manualsonline.com/
Dual Car Audio &... | Answered on Nov 01, 2018
Search up Google and enter your amp (name and model #) , and it should show you a pdf manual of that amplifier and show you that , possibly a 3-channel set-up would fit your needs, 4 ohms is usually the lowest minimum for the middle mono channel. Then, you could run the other two L & R channels for your mids and tweets (in stereo) on the remaining two channels; thereby in keeping a single amp to run the entire system. Also, 2 ohms would usually be the normal minimum on same amp for stereo amp output abilities, so that could easily run 5 speakers off one amp. I did it for years on a RF-600a4 with one 12" sub, and two 6 1/2" midbass, and two tweets (usually Morels, or Image Dynamics). Hope that helps...
Dual Car Audio &... | Answered on Oct 06, 2018
Dual XDM6830 CD Player Logo
4 questions posted
Top Dual Car Audio & Video Experts
xxxxxx xxx
Mike Duncan
Mike Duncan
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Dual Car Audio & Video
Most Popular Question
cd player not working reads error02
  • Car Audio & Video
