20 Most Recent Bluebird Microphone Questions & Answers
Black inside wire severed
what device?
1/31/2013 1:48:52 AM • Bluebird... • Answered on Jan 31, 2013
0answers
Just got the bluebird and am trying to use with
This microphone requires phantom power to operate...so that could be your problem. maybe.
4/17/2010 6:37:44 PM • Bluebird... • Answered on Apr 17, 2010
2answers
Pairing with blue tooth earphones
It is very unlikely that your MP3 player is BlueTooth. Make and Model or the player and the earphones are needed in questions like these or we are working blind and guessing. Click COMMENT to report back. Read this though. Tip & How-To about Miscellaneous Pairing Bluetooth Devices Posters often ask "How do I pair my Bluetooth ???" Insert whatever device you have at the question marks. Generally, you need to read the instructions for the camera, headset, speakers or whatever the Bluetooth device is. Roughly speaking though. Settings - Bluetooth - Search, on the Android, iPhone, Windows phone whatever. With camera, speaker, headphones or whatever the Bluetooth device is, you have to press a button on that device to send out the signal. On my Bowers and Wilkins T6 Speakers, there is a button on the top with the Bluetooth symbol on it. This is the part people usually don't do and ask for advice, thinking it will do this automatically. When the Android device recognizes it, click Pair, and if it asks for a code, the Default is '0000', (four zeros, no quotes). Posted by ADMIN... on Nov 19, 2016
10/14/2022 8:08:18 AM • Blue Audio... • Answered on Oct 14, 2022
DAB 307 flashing blue light with intermitent welcome to DAB radio clock not set
That means it is unable to initialise because it cannot find a signal.
2/13/2022 8:09:24 PM • Blue Audio... • Answered on Feb 13, 2022
Ipod docking station ISPK2806 won't turn on no blue light
Did you read the instructions? Did you press that larger button on the left side. Did you try something else in the wall socket? It is a 2006 unit! https://www.ecoustics.com/products/coming-ilive-and-time-speakers/ I don't see any blue light, that is the remote control sensor https://www.manualslib.com/manual/76093/Ilive-Ispk2806.html#manual ..
12/31/2020 2:29:45 AM • Blue Audio... • Answered on Dec 31, 2020
Why is my transmitter flashing white to blue
  • Check that the transmitter AC power adapter is fully inserted into the wall outlet and the power cord from the AC adapter is firmly connected to the transmitter power input jack.
  • If you're using the speaker power adapter, confirm that it's fully inserted into a wall outlet and the adapter power cord is firmly connected to the power input jack on the speaker.
  • If you're using batteries for the speaker, check that they are fresh and inserted with correct polarity (+, -).
  • confirm that the speaker is in 900MHz wireless mode-the indicator light on the front of the speaker should be either fl ashing or solid green. If the indicator light is blue, press the ON-OFF / RF-BT button on the back of the speaker to switch to 900MHz mode.
  • confirm that the speaker is turned on and tuned to the transmitter-the indicator light on the front of the speaker should be solid green (not blinking).
  • Check that the audio source component (stereo, MP3 player, etc.) is turned on and transmitting sound as it normally should.
  • Make sure the volume on your audio source is turned up.
  • Check that the speaker volume is turned up.
  • Make sure you have disconnected the 3.5 mm audio in cable from the AUDIO IN jack.
8/26/2018 7:36:54 PM • Blue Audio... • Answered on Aug 26, 2018
How do I turn off blue buzz on my NELSONIC radio?
http://www.fixya.com/support/t24221317-set_presets_nelsonic_clock_radio_nlc_618
1/26/2018 12:18:06 AM • Blue Audio... • Answered on Jan 26, 2018
I canot find my listing second time listed rosette 72 bass dark blue mint cind
You are on the wrong website for this type of inquiry. This is a community based self-help website for the repair and use of manufactured products made for consumer use
7/6/2017 7:11:23 PM • Blue Audio... • Answered on Jul 06, 2017
Bluebird Microphone Logo
Popular Tags
9 questions posted
Top Blue Audio Players & Recorders Experts
 Grubhead
Grubhead
ADMIN Andrew
ADMIN Andrew
Are you a Blue Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Blue Audio Players & Recorders
Most Popular Question
just got bluebird am trying use
  • Audio Players & Recorders
