20 Most Recent Audio Technica ATH-A900 Professional Headphones Questions & Answers
Need to repair a cut wire going from the left ear cup to the right ear cup
In fact the insulated inner wire (the white tube) is the signal carrying wire. The outer wires without insulation are connecting ground (GND). Both wires have to be connected to the speaker in the ear piece in order to (re-) build a circuit.
7/12/2017 9:08:51 AM • Audio Technica... • Answered on Jul 12, 2017
How do I open Audio-technica ATH-911's? One of th...
hi.First of all: This headphones don't have a single srew. So be extremely carefull as everything is glued !#1 - Removing the logo plateThis isn't need to reach the wires. Just for cleaning purposes.Remove de soft ring-pillow from the earing.Remove the textil thick black ring that is glued by the internal outside gently.Look for the three black metal small wings that belong to the logo plate and are inserted to the internal side and are glued and/or bended. Unbend them.Then pull this wings in order to extract the plate by the outside side the logo plate.#2: Accessing the speaker and it's wires.This is a very carefull procedure. A mistake and you'll have scrap instead!Remove the soft ringed pillow from the earing. In the border that the blacksinthetic leader was inserted, insert a medium screwdriver. Gently swingthe driver up and down in order to separate the plastic disc that supportsthe ringed pillow from the outside hat of the earing. Do this in circles fora couple of times or until you begin to ear the glue lightly cracking. Afterthis the plstic disk separates from the outside hat and all the electricwiring and speaker are free to repair.NOTE: A piece of advice: do NOT use instant glue or cyanide glue to re-assemble. It would be the last repair! Pedro Regueiras
12/18/2011 4:31:00 PM • Audio Technica... • Answered on Dec 18, 2011
2answers
Audio-Technica AT-LP120 turntable. I have crackling in the passive speaker, but when I reverse the speaker wire,ie, red in black & black in red, the crackle appears in the powered speaker.
If you have replaced the cartridge then it must be the cartridge pre-amp that is faulty. If there are any other functions on the device such as CD, then it will not effect them. Unless there is crackling on any other function then the pre-amp has a problem. The pre-amp itself is generally a single IC. You can find it by following the turntable connection back to the inside of the amp. The signals will pass through the IC before being passed to the main pre-amp.
11/26/2022 12:35:40 PM • Audio Technica... • Answered on Nov 26, 2022
Brand new audio technica turntable and we’ve lost the left channel. Its not the reciever, the cd, dvd, works fine.
Use an alternative device connected to the input the turntable usually connects to. If both channels work ok the new turntable is clearly faulty and should be returned under warranty.
3/5/2018 1:03:45 AM • Audio Technica... • Answered on Mar 05, 2018
3answers
Can you please give me vodafone 543 codes of sound
please give me equalizer code vodafone 543
3/28/2017 3:56:29 PM • Audio Technica... • Answered on Mar 28, 2017
Audio Technica ATH AD700 headphones. Broke the jack on these and local repair shop has put wires back incorrectly. Please does anyone have a wiring scheme I can pass on? Thank you very much!!!
You should go back to the local repair shop and ask them to do the job right or to give you the money back you presumably paid. You have a legal right to have them fixed properly.
2/10/2017 8:45:15 PM • Audio Technica... • Answered on Feb 10, 2017
Audio technica at 120 cartridge will fit my project essential?
Having looked at the turntable it seems to mount the cartridge with two bolt like fittings. The Cartridge you want has two mounts on the side that will take those bolts. You will have to adjust the arm to compensate for the weight differences between the two cartridges, but once done it should play fine.
7/28/2016 2:56:45 PM • Audio Technica... • Answered on Jul 28, 2016
Hi. i have a audio technica atn91 cartridge for it and want to know the tracking force and the counterweight i should set?
I have used this article to set up my dual turntable. Cartridge Alignment The Basics Explained Tracking force: 1.5 to 2.5g Your cartridge specifications are in the following link. Audio Technica AT91 Hope this helps?
3/23/2016 10:47:21 PM • Audio Technica... • Answered on Mar 23, 2016
Audio technica turntables issue AT 60-LP usb the start and stop buttons no longer work the drive doesn't turn. Belt is fine. the wires that push internal mechanisms are no longer connected. Help
There are a number of helpful videos on YouTube about this model turntable, it might give you the answer you need.
2/28/2016 7:12:32 PM • Audio Technica... • Answered on Feb 28, 2016
The left side of my headphone is not functioning. Is this possible to get repaired?
Normally, yes. If you'\'re not sure how to track down the part that's broken, contact the maker for an ra to return it for service.
6/19/2015 1:16:24 AM • Audio Technica... • Answered on Jun 19, 2015
I need a wiring diagram for the mic end of a audio technica at822 the wires all broke at the solder points
This is the only thing I could find online: 1 - shield 2 - left (hot) 3 - left 4 - right (hot) 5 - right
4/13/2015 9:45:35 PM • Audio Technica... • Answered on Apr 13, 2015
Audio Technica ATH-A900 Professional Headphones Logo
3 questions posted
Top Audio Technica Audio Players & Recorders Experts
 Grubhead
Grubhead
Paul Bade
Are you an Audio Technica Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Audio Technica Audio Players & Recorders
Most Popular Question
need repair cut wire going from left ear
  • Audio Players & Recorders
