20 Most Recent
M-Audio MXL 990/991 Recording Mic Duo and Audio Buddy Package Microphone Questions & Answers
Problems with my MXL 990
Sounds like the frame of the microphone itself has become ungrounded. You could try VERY
carefully disassemble the mic and check for a bad ground or a bad wire connecting to the mic
body.
MXL 990 doesn't work
Your other preamp does not have phantom power to supply power to the microphone. All condensor mics like this need phantom power. The Audio Buddy provides phantom power, which is why it was shipped with those condensor mics
I have a mxl 990
Try increasing the latency. Depending on your computer, it may not be able to handle low latency levels. Latency is a measure of the delay between the time you make a sound and the time the computer records that sound. With the Mbox mini, the unit for latency is the number of samples the driver collects before sending them to an application as input. Lower latency can make recording easier and more accurate, but not all computer systems can operate at the lowest latencies without introducing noise.
Open the Mbox mini dialog and select the latency tab. experiment with higher latency levels and see if it goes away.
This is what the dialogue might look like.
another solution would be to try a different DAW. I had the same problem with my Fast Track Pro in ProToolsand it worked fin on Reaper, Garageband and Logic.
I recently bought the M-Audio
hello matt. It may be a case that a preamp will help. It will boost the level coming off a mic. The ART preamps have tubes, are inexpensive, AND some of them have a pretty useful compressor into the bargain.
I use the Presonus TubePre, and that has worked well. You can run it pretty clean, or you can drive the tube a little harder for a bit of tube compression/distortion.
If I was buying today, I'd be inclined to consider the Presonus AudioBox USB 2x2, which would be a brand new interface that should also function as a preamp. About $150, so more than the ART's, but might be a great all-in-one solution. It might also be economical, if your M-Audio piece isn't a good match for the equipment you have.
You've probably already done this, but it might be worthwhile to patiently work your way through your recording chain and see if there's anything set lower than normal, including outputs on the keyboard and the inputs to the Mac, including the main Audio preferences and the GarageBand Audio preferences... Check for pad switches on your equipment, anything that might be a simple fix...
I have a m-audio buddy
It appears that the condenser microphones that are omni directional are too sensitive to process thru an amplifier. I used an mlx 991 directional condenser microphone and though still very sensitive, I was able to avoid the feedback. According to the company condenser microphones are used more for recording and not so much for live stage.
M-audio buddy feedback from mlx 990 condenser mike
Hey I Have These Mics They Work Awesome. But Yes Feedback Is A Problem You Need To Move Away From The Speakers Way Away. Try Lowering Your Highs Or Invest In A Feedback Eliminator They Are Like 89 Bucks But Obviously That Would Almost Cost As Much As The Mic Set. Anyways Feedback Is Made When A Microphone Can Hear Itself Maybe Try Headphone?
Bass Guitar Won't Register
The mics I have seen don't have a filter... but a lot of mixers do have a 100Hz mic input filter. Check the other equipment that you are using also.
Audio bx5a tweeter
Tweeter just may need to be replaced. Is all the sound coming only from the woofer?
Loud rattling noise
hey shawn, try lowering the volumne level & see how the speakers react. www.tiger direct.com has new computer speakers,all different prices & different quality levels. from the best to the cheapest computer speakers.they carry all computer parts. 2 tb hard drives, $89.00for usb2 & usb 3 ports.
