20 Most Recent
Samsung SlimFit TX-S3082WH 30" TV Questions & Answers
How to enter into service mode with sony
Using the remote control: # Turn the TV off. # Press {DISPLAY} {5}
{VOL+} {POWER ON} buttons. or Press {DISPLAY} {5} {POWER ON} buttons.
# The Service Menu will be displayed. # Use numbers {1} and {4} to
select the item to adjust. # Use numbers {3} and {6} to adjust the value of
the data. # Press {MUTE} then {ENTER} to save new settings. # The words
"WRITE" in red will show up in the upper right corner if saved. # Turn the
TV off to exit the service menu.Service mode entry method will differ model to model. If you wish
to get more details, check this link.
http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic
/ Time slide, can be selected by the drop-down list, at the top left
of the display window, will make surf easy. You can also do a search, by type in the brand name/model
number/IC used, in the search box at the top right of the display window.Service mode entry procedure to different models of Sony TVs are given in detail. The above stated procedure is for one model only.
Schematic SlimFit CS21B850F6
Schematic diagram is in PDF, and cannot upload by this window. If
you wish to get more details, check this link.
Mosaic
My tv has a problem
Check the electrical outlet which the tv is plugged into. Make sure nothing is loose at the outlet as well as on the back of the tv where the power cable plugs in.
Another thing to try is plug a different device into that same electrical outlet and see if it turns on/off as well. If that device also turns on/off by itself, it could be a faulty outlet.
TV doesn't come on.
I could be the capacitors problem on your power supply circuit. Just has it checked and replace the defective one
My Samsung TXS3082WH 30 inc
There have been a lot of problems with the Samsung sets, one dealer I know had so many complaints about the ones he sold he stopped selling them and switch to another brand and he has been trouble free ever since. To answer your question they have problems with the screens, color texture, lines, fade out to name a few, from what you have described you have at least two or three issues, considering the history I would replace it.
My television is a Samsung Slimfit tx-t2782 and
I AM HAVING THE EXACT SAME PROBLEM WITH MINE ! But before mine turns off, it shows a blurry squiggly red mark on the screen then shuts off and wont turn back on sometimes for several hours.. And everytime I CAN get it back on, I have to unlpug the whole thing and plug it back in...
When i turn it on it has an horizontal blue line
the set having blue scteen when the nosignal condition so blue horizontal line due to failure in vertical deflection section and system control detect the vertical delection failure . so system control farce to set to shut down pls repair the vertical section and system should be ok
I have a HDTV Samsung TV, Model #TXS3082WHX/XAA
Look for a monitor cable with 15 pin RGB plugs on each end, that will transmit the video portion of the signal so you will need an audio cable with 3.5mm plug on each end also, there are RGB cables that have the audio cable together as one big cable.
Good Luck !
My volume stopped working on my panasonic viera
Make certain that it is not muted or turned off. If it isn't check to make sure that the audio type matches what you are watching. If you are on SAP and there isn't anything on the channel in SAP the audio will be dead. If all those check out you probably have a bad control board. $130 to $200 to fix. Let me know how things work out.
hardrocko
