20 Most Recent Philips DVP3040 DVD Player Questions & Answers
0answers
2answers
Unlock region code
Keep Tray in eject position
Press Setup from remot
Go to preference page
Press"138931"
Using Navigation Key chane region code to "0"
Press "OK"
OR
open tray
press 98790
7/12/2017 6:46:02 AM • Philips DVP3040... • Answered on Jul 12, 2017
Philips dvp 3868GX-94
Sadly I don't know where you are in the world, which affects the registration. I have assumed you are in India in which case you register it here: Register your product Philips product registration
6/20/2014 11:54:20 AM • Philips DVP3040... • Answered on Jun 20, 2014
0answers
0answers
Need a drive belt for a philips dvp3040/37 its
Hi: i search belt and head fo my tape recorder philips aq 6455 and philips d6350. Thanks.
[email protected]
4/11/2011 4:49:30 PM • Philips DVP3040... • Answered on Apr 11, 2011
I can not remember my
Try using the password 136900. If this works for you, then using your remote, access the general setup menu and choose the Disc Unlock option.
Hope this helps!!
3/6/2011 11:48:32 AM • Philips DVP3040... • Answered on Mar 06, 2011
Phillips 3040 dvd player is asking for a password
Try using the password 136900. If this works for you, then using your remote, go to the general set up menu and select the Disc Unlock option.
Hope this helps!!!!
3/6/2011 11:00:52 AM • Philips DVP3040... • Answered on Mar 06, 2011
Só le cd audio naum
Hi its look that you need to clean the laser lens
manualy open the cover press eject unplug the dvd leave the door open and with a qtips and alcool wipe gently the lens
and its done put the cover back and try it its should works
and make shure that you have a clean disk before try to play it
hope that will help you
regards Alan.
10/13/2010 4:34:40 PM • Philips DVP3040... • Answered on Oct 13, 2010
Non si apre il cassetto e sul display compare la
Firstly if there is a dvd stuck inside the machine and it won't eject then try the following: Turn off the power at the plug socket and remove the plug then look on the underside of the machine. On some Philips dvd players there is a plain white label below where the dvd tray sits under this label is a slot which gains you access to the manual release. If there is a label and slot gently pierce the label using a small screwdriver and push the screwdriver gently in until it stops then move it from right to left. This action moves a lug sited under the drive unit, this lug is the manual release for the tray. You will then see the tray open and will be able to remove the disc, moving the lug back will close the tray.
But this problem on Philips dvd players and recorders is a fault with the dvd drive and is common on some Philips machines. The only way to cure it is to replace the dvd drive unit itself, the one positive is that Philips used their standard IDE or SATA internal dvd drives, the same as in desk top computers. However a replacement drive would have to be comparable to the exisisting unit to avoid further complications. Please take note as a safety warning this is a technical solution involving the opening of the machine exposing potentially live electrical parts and should only be under taken by a trained technician.
Hope this info helps, James
4/22/2010 11:33:21 AM • Philips DVP3040... • Answered on Apr 22, 2010
Wavy lines
bad connection, check or change leads.
2/27/2010 8:45:46 PM • Philips DVP3040... • Answered on Feb 27, 2010
My daughter (6) accidentally dropped the remote
Tries Website 1-800-Remotes Factory origial.Buy an original remotes.
2/27/2010 1:36:30 AM • Philips DVP3040... • Answered on Feb 27, 2010
Unlocking a Philips 3142
HELLO!
I think you will find this useful!
Switch on the player Then open the disc tray
Press 9879 and the region code number you want to set the player to.
Hope this helps you! (:-).
8/20/2009 12:05:01 PM • Philips DVP3040... • Answered on Aug 20, 2009
Dvd on lock
Dear friend,
Pls upgrade ur dvd player. the problem will be solved.
3/29/2009 8:44:49 AM • Philips DVP3040... • Answered on Mar 29, 2009
Ascolto suoni
Only in english... sorry!
Perhaps the audio that you don't ear is the DTS audio track in some DVDs.
Choose another audio track, like 5.1, 6.1 or Stereo
2/27/2009 7:26:28 PM • Philips DVP3040... • Answered on Feb 27, 2009
Region code
Type in region codes for DVD players in google
1/17/2009 12:25:05 PM • Philips DVP3040... • Answered on Jan 17, 2009
Philips DVP3040 DVD Player Logo
35 questions posted
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Philips Televison & Video
Most Popular Question
unlock region code
  • Televison & Video
