20 Most Recent Frymaster Dean H55 Deep Fryer Questions & Answers
0answers
My Frymaster SR114 electric fryer keeps tripping
Defective thermostat.
8/29/2015 6:54:30 PM • Frymaster Dean... • Answered on Aug 29, 2015
Pilot light will not stay on
Defective thermocouple. It is the metal tube that is in the flame of the pilot light.
8/29/2015 6:40:10 PM • Frymaster Dean... • Answered on Aug 29, 2015
How to clean blocked pilot orfice
One time this happened to me on a gas stove. I used an electric drill with drill bit to clean it out. It will only work if the line is straight, no bends in the line.
8/29/2015 6:25:18 PM • Frymaster Dean... • Answered on Aug 29, 2015
How do you release the grease
Here's a link that may help,find your model and click on it,k. http://www.frymaster.com/minisite/service/manuals
8/4/2015 3:22:53 PM • Frymaster Dean... • Answered on Aug 04, 2015
Do i need a pressure regulator
always
7/1/2015 12:17:08 AM • Frymaster Dean... • Answered on Jul 01, 2015
My deep fryer pilot light dose not stay light, why is it happening?
This might be due to a loose wire in the light that or it is going out.
2/17/2015 11:48:51 PM • Frymaster Dean... • Answered on Feb 17, 2015
I'm not sure of the name of the parts, when the fryer is turned on flames come out of the bottom of the three front pillars? I'm not sure how to stop the problem. I've removed them and cleaned out so
Drill out all the small holes on the burners(pillars). Remove them by taking out the two bolts at the top of each burner.
1/27/2015 1:54:23 PM • Frymaster Dean... • Answered on Jan 27, 2015
Can anybody tell me what's wrong with this? Any suggestions please and thank you.
The burner or the burner venturi is clogged. The burners are held in place with 2 bolts at the top and you need a 1/2 inch wrench. Remove the bolts and lift the burners off the brass orifices. Make sure all the holes are clear. If they are clogged they need to be drilled out. You should not have yellow in the flames in the burner tube.... kinda looks like the are sooting. This causes flames to come out the bottom of the burners.
1/27/2015 1:52:12 PM • Frymaster Dean... • Answered on Jan 27, 2015
2answers
Pilot light lights but is a low flame
There is an adjustment screw on the main gas valve, usually under a cover screw. It will be near where the small pipe that goes to the pilot light.
7/30/2014 10:24:33 AM • Frymaster Dean... • Answered on Jul 30, 2014
0answers
0answers
0answers
Flames come out from the pilot area heavy until unit gets to temp
venting is bad ---- soot build up - obstructions---------clean your unit
3/5/2014 5:38:50 PM • Frymaster Dean... • Answered on Mar 05, 2014
0answers
Frymaster Dean H55 Deep Fryer Logo
4 questions posted
Top Frymaster Dean Kitchen Appliances - Others Experts
Paul Carew
Thomas Perkins
Thomas Perkins
Are you a Frymaster Dean Kitchen Appliances - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Frymaster Dean Kitchen Appliances - Others
Most Popular Question
pilot knob turn turn off still in pilot
  • Kitchen Appliances - Others
