20 Most Recent
LG LRE30755 Electric Kitchen Range Questions & Answers
Burner on range will not turn off
Look at the back of your range there should be schemetic for your power control board. look for defective burner wire going into relay. There should be 5 relays in rows. Realy is the problem. I had the same problem with my front left burner stuck on high.
After replacing everything works okay.
Alum stuck in oven
what i suggest to another customer is to get some of that new easy off that's made for self cleaning ovens and soak it in that for awhile the customer never respond back so i didn't know if it worked now as far as getting i cant say only as the foil is not a warranty issue you really don't need it in a self cleaning oven
How to remove lower drawer LG Range model lre30755sb
Pull the drawer all the way out. There is a clear plastic lever at the back of the track with an arrow next to it. One side points up, the other side points down. Move the levers in the direction that the arrow points and the drawer will release from the track for removal.
My lg electric range gives a f3 when oven is used
ou need to check the resistance of the sensor at the control board.
Unplug the oven, open the control panel and locate plug J3 at the control board.
Disconnect the plug and check the resistance between two white wires. The meter set for 10 kohm.
At the room temperature the resistance should be around 1100 ohm.
Check the wire harness between the sensor and the control board.
Only then if everything check out fine - replace the control board.
Here is the part to order.
I have LG stove and does not heat up. when I
Consult the papaer insert that comes in the range to find out what error code F 7 means. You might be able to Google it.This sounds like a gas stove and you are talking about the oven.Not having the model number nor being familiar with this LG I can only hazard a guess that the control board is locking out. Problem could be in the spark board or the gas valve. Less likely in the electronic board itself.In future, always try to give as much info as you can as you are the one standing by the machine.
Range top front burner will not shut off, stays on
I have the same problem with the LG LSB5682SW Electric Range - Font Left Burner will not go off / stays on high. This is very dangerous. LG customer service is horrendous. I think it is time for a recall before someone's house burns down!
No power after self clean
I have the exact same problem. I called for service and was told I will be better off replacing the unit. This was probably the second time we used the self cleaning feature after about three years of service.
When was this model LG stove LRE30755
Hello &
Welcome to FixYa
Sorry don't
know the exact date when it was discontinued however, you can buy its parts
from this link. Please get back to me if you have any other questions.
Kevin
