20 Most Recent
Denon DP-26F Turntable Questions & Answers
Replace cartridge stylus
Hi, my advise to customers is to buy the best quality audio gear you can afford. If you tell me your budget I will suggest a couple of carts that match. Cheers John. Styluscity
I just bought a used DP26F and see that under the
This picture is from the manual for a DP-29F, a similar belt-drive turntable:
The view is through the rectangular hole in the platter you see with the turntable mat removed. This picture is from the setup section for a new turntable, so the ribbon tape won't be on your belt. But it shows how the belt should go around the drive roller (it's the shaft of the drive motor underneath). Other than the routing of the belt over the roller, there's nothing else to connect. If the belt is working correctly (hasn't stretched so it's too loose), the roller drives the belt which in turn spins the platter. If your turntable isn't turning, either the belt is too loose to transmit the motion, the drive motor isn't spinning, or something is binding and preventing the platter from turning.
Denon turntable DP 26F turntable doesn't turn
through the platter motor access window, unhook belt from motor spindle (usually brass) which is exposed on the left side when you remove the mat.
Now give the motor a spin with your thumb/index finger. repeat up to maybe a dozen times. sometimes a motor like this will get a dead spot where a bit of debris will 'gum up the works' and stop the electrical contact it needs to spin.
if it does start working by some miracle, then just let is sit and run at 45rpm for hours or even days, this may kinda rub off some very light corrosion that might have built up on the armature over the years. (if it is a brush type motor)
Size of fuse for Denon dra 697
The Denon DRA-697CI stereo receiver typically uses a 250V, 2.5A fuse. However, it's always a good idea to consult the user manual or check the label near the power input on the device itself to confirm the exact fuse size and specifications for your particular model. Using the correct fuse size is important for safety and to prevent damage to the receiver. If you're unsure, you can also contact Denon customer support for assistance.
Fuse size for Denon DRA 697 c!
The Denon DRA-697CI is a stereo receiver. Typically, the fuse size for electronic devices like stereo receivers is listed in the device's manual or on a label near the power input. It's important to use the correct fuse size to ensure proper protection against electrical faults.
Without specific information about the fuse size for the Denon DRA-697CI, I recommend consulting the device's manual or contacting Denon's customer support for accurate information. Using the wrong fuse size can potentially damage the device or pose a safety hazard, so it's crucial to verify the correct specifications.
