20 Most Recent
Philips SBP1100/37 Portable Speaker System Computer Speakers Questions & Answers
I am not sure I
the plugs usually red green and black/blue
if your computer came with
a motherboard disc the sound drivers could be on it
click start control panel
administrive tools computer management device manager scroll to sound,video and
game controllers you might see a yellow question exclamation mark? ! or a red X
Right click to reinstall drivers
sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers)))
also audio you will find 3 drop down lists make sure you have the correct
settings there
also
sounds and audio devices select advanced there might be a tick in the mute box
untick it
sounds and audio devices you can adjust the volume there also select speaker
volume you can change your settings there you can also tick in the box place
icon in taskbar for any sound settings by right clicking on the speaker icon
then you are ready to position your speakers if you have
more than 2 you might need to select stereo
hope this helps
7/30/2011 7:33:32 PM •
Philips...
Answered
on Jul 30, 2011
Why is it that only one of my Philips speaker is
try swapping the speakers around if the problem still persists either the speaker is faulty
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
6/15/2011 11:15:19 PM •
Philips...
Answered
on Jun 15, 2011
Computer will not recognize Philips
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make sure you have selected the right speakers or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers if you have tried this you might try
control panel,administrive tools,computer management,device manager,sound,right click select properties to either troubleshoot,uninstall,rollback driver
hope this helps
10/28/2010 8:45:32 PM •
Philips...
Answered
on Oct 28, 2010
How to install philips portable speakers to my hp computer
use a multi-out jack....it will have two out jacks(female) and one pin(male) to be inserted into the audio out jack on the computer, connect your speakers pins(male) to those 2 out jacks....
look for this.....buy it on ebay look for "Audio Spliter"
guess this helps...pls let me know leave a feedback for this solution...
reg
4/27/2010 4:28:12 PM •
Philips...
Answered
on Apr 27, 2010
Very very low sound/output
Helle there!
First!
1) check your setting for sound to (2 way speakers)
2) Setting for Volume in control panel.
3) connector may be you need a little expantion from radio shack gold ext.
4) be sure you got sound from headphones !! **
Go it!
3/9/2010 5:06:21 AM •
Philips...
Answered
on Mar 09, 2010
My Philips SBP1100 speaker' volume is not loud enough
Were they ever loud? If they weren't (which is my guess - judging by the picture) is that they are low wattage which essentially means that they are not intended to be loud. They are most likely to be used as a small compact, low-noise speaker for a smal MP3 player where high (club-vloume) wattage/volume is needed. If they used to be loud check the volume control on your laptop and check each and every setting that there is. One stupid little setting could be a big difference. Audio Properties in the control pannel could be helpful but don't mess with those settings in the control pannel unless you are almost positive as to what they are and what they do. You could cause yourself a bigger problem. Remember that most laptop speaker outputs are actually for headphones and are not intended to go super-high as they are designed for headphones and not to hurt ears at high volumes. Hope this helps. If not try checking back with me. Best of luck. Bonne chance!
10/24/2009 4:43:30 PM •
Philips...
Answered
on Oct 24, 2009
Connecting speakers
Hello there!
First things first!
1) Connect the speakers to out on PC, press carefully .
2) Go to control panel and see on multimedia , that sound is enable, and not in mute. pop up volume.
3) may be is defective speakers? go and RMS the Speakers, if got warranty or change for another.
4) Good Luck!
8/25/2008 4:28:06 PM •
Philips...
Answered
on Aug 25, 2008
Very low output
Are the Philips speakers powered ????
Try in the headphone socket on a radio and check the sound then.
8/1/2008 10:01:55 AM •
Philips...
Answered
on Aug 01, 2008
I have a Philips Kitchen
The skipping problem you are experiencing may be related to the shaft that the laser assy rides on. It may need a little greasing with silicon grease, just a litte bit. Or it could be the spindle motor is wobbling as it turns. If you are a little tech savy, then you can order a new CD drive assy through Ebay and swap it out when it arrives. If you get this far you need to know how to remove the solder short on the new assy otherwise the new drive will not work.
Does aj300d/05 have a fuse
The Philips iPod dock model "AJ300D/05" is not responding when plugged in. To troubleshoot:
- Check the power source and ensure proper connection.
- If applicable, look for any blown fuses as a potential issue.
- Verify the dock connector for a secure connection with the device.
- Confirm device compatibility and consider using adapters if needed.
- Check the remote control and its batteries.
- Look for a reset function if available.
- Update any associated software.
- Inspect for physical damage.
If none of these steps resolve the issue, reach out to Philips customer support or a professional technician for further assistance or potential repair.
Why doesn't my Philips CDR820 copy a disc when I press "copy cd" then the "yes" button?
If your Philips CDR820 is not copying a disc when you press the "copy cd" button and then the "yes" button, there could be several reasons why this is happening. Here are some possible solutions you can try:
- Check the disc: Make sure the disc you are trying to copy is not scratched, dirty, or damaged. If it is, try using a different disc.
- Check the blank disc: Make sure the blank disc you are using is compatible with your Philips CDR820. Check the user manual for compatible disc formats.
- Clean the laser lens: If the laser lens is dirty, it may not be able to read the disc properly. Use a cleaning disc to clean the lens.
- Update the firmware: Check if there is an available firmware update for your Philips CDR820. If there is, download and install it to see if it fixes the issue.
- Reset the device: Try resetting the device by unplugging it from the power source for a few minutes, then plugging it back in and trying to copy a disc again.
If none of these solutions work, it may be a hardware issue that requires professional repair. In that case, you may need to contact Philips customer support or a qualified technician for assistance.
