20 Most Recent
DISH Network 811 HD DTV Receiver Questions & Answers
Since we upgraded our cable tv service to
Hi martymeowmy name is Mike Houston of DISH Network and after reading over your post thereare some things that can be done. Please press the buttons of MENU-6-9 and youwill be on the Closed Caption screen and press the tab that says Captionson/off and make sure the ON tab is checked.
My dish 811 receiver won't download guide info.
Pull the smart card out of the unit and turn the unit off. then turn it back on and replace the card. this should reset the unit. It will take a minut or so for the unit to read the card and aquire a sat signal. If this does not work, simply call Dish network and they can walk you through any other options.
HI. I am deaf, okay
Call dish network they maybe able to help maybe new tv isnt synchronized or you may haft to program? anyhow good luck hope it works for you!!!
Dishnet 811 unpluged during downloadfrom satellite
yeah that is a software download, if it does not progress it may have an issue, those receivers are being discontinued, call dishnetwork and they will provide you with a replacement leased receiver and a new dish install to receive all current hd programming
Can you use your dish Network remote to control your VCR ?
If the dish network remote control is universal it may work with limited functions. If the remote control has buttons labeled cd, receiver, cable or Aux etc. it might work. The manual will tell you for sure. It will also provide you with the proper code for the component to work.
