20 Most Recent
RCA 27F634T TV Questions & Answers
Rca F35720SB makes popping noise then shuts off
It may be arching from the flyback. If you are familiar with tv's remove the plastic case plug it in and turn it on and see if you can see anything visual happening. Make sure not to touch anything and keep a safe distance when inspecting.
RCA 27F634T LED blinks 25 times
SDA [Serial Data] bus is busy or interrupted. Seek tech support. This is a very skilled work, need all measuring instruments, and through knowledge in electronics.
Picture has dropped
Visit this site for more details. Type in the site name "Electro-help" either Google or Yahoo search box [not
in the address bar of your browser], and click search. It is an electronic equipments service help
site. All details you want are
there. Note the position of
hyphen in between words in site name, when you type it in. The site will appear as it is in
web; subtitled as service help to electronic home entertainement equipments.
Pull up older posts.
You can gather all details.
Sometimes, click open the adverts' by the side and bottom of each post
might give you more details.
Necesito data eeprom de tv rca 27f634t chasis a al encender pocos
cambiale el flyback y ponle la memoria original de vuelta. cuando encienda trata de ajustar el control de screen en el flyback hasta el punto en que cuando cambies los canales no se apague. creeme que esto me tomo mucho tiempo en encontrarlo pero al fin lo arregle. The Tech
The tv clicks on but
Hello
If the tv clicks SEVERAL times like it is trying to start but just cant make it over the hump this is "GENERALLY" a power supply problem. Bad Caps tend to make this happen and are fairly easy
to change by someone with a little know how. However, the bad caps could be hiding a larger
issue that only someone who is skilled can really troubleshoot.
If your tv is suffering from a powersupply many times they can be purchased on ebay, or sometimes you can find them totally rebuilt.
I hope this helps
RCA model 27F634T
on that one ive had the button board causing problem--remove board--spray wd40 on buttons--push buttons a few times--wipe off bwd--reinstall bwd
TV won't turn on
you may need the digital converter from radio shack or best buy
It won't turn on.
You will need to replace the transformer on the power sector. it has failed.
Problem with RCA TV Model 27F634T
You almost certainly have a bad picture tube. The green screen was from one of the elements inside shorting out. The static sound you're hearing is the high voltage arcing out through the end of the picture tube to other parts inside the set. It's more economical to buy a new TV than to repair this one.
Sorry to have such good news, but this is one of the ways a picture tube can go bad, and it happens quite often.
RCA 27F634T
Have you tried to access the menu features and tried to retune the stations on digital, or are you hooked up for analog.
If you don't know about what i speak, give me a yell.
[email protected] I believe my remote sensor card is bad. While this might explain why you can't turn yours off, it would not explain the blank picture. If the menu does show, i would think the picture tube is O.K. if the menu does not show, there are some other things to look at.
Tv stopped working
i need the make and model of your television.. usually the red light blinks out a code. i need to know how many times it blinks as well. so i can find out what code it is producing.
Black and white screen only on DSTV?
RCA video cables handle analog signals. HDMI cables carry digital video signals. You need a converter. If you are using a component video converter, check if you swapped two of the three RCA video cables. (There are some A/V projectors that can do the translation of RCA and HDMI internally. Most TVs do not.)
I hope this helps.
(One of my family's TVs used a dongle to condense the analog video signal to a single port, swapping blue and green gave a black and white output, IIRC.)
I have an RCA re20qp80 remote that the mute button doesn't work
Most modern tv remotes are not normally designed to be repaired. You will possibly need to replace it. there are plenty of cheaper after market version that will do the job just as well. Your other option, and yes I know this is a silly answer, when you want to mute the TV is to simply press the volume down button to zero then turn it back up when you want sound.
How to connect rca vr667hf to tv
you will need to rind RCA to whatever input is on your tv google RCA to HDMI
copy and paste link for manual
https://www.manualslib.com/manual/313476/Rca-Vr677hf.html#manual
