20 Most Recent
West Bend 84496 6-Quart Slow Cooker Questions & Answers
When I turn it on I get E01
- The thermostat may temporarily lose calibration due to temperature changes resulting in an E01 error message on the display. Repeat the following steps to reset the unit.
- 1. Unplug the unit from the wall socket for approximately 10 seconds.
- 2. Plug the unit back into the wall socket.
- 3. Press the POWER button once. Within one second, press the COOK button once. The unit should now be rese
West Bend Slow Cooker error
if you put something frozen or cold in it and let set for awhile without turning on then you must take it out let unit get room temp. then start it . E01 error means the unit is too cold to start.
West bend slow cooker model
NO, these stoneware inserts are not meant for the high dry heat of conventional ovens. It will crack in the oven...use only in the crockpot!
LID
https://www.focuselectrics.com
Go to productsm find yours and select it. There will be a number to select for the parts list. A New lid with knob is under $6 + Shipping
Good evening!
Can the ceramic insert
seems rather plausible, however wouldn't it be best to visit the company website - and -- or download an owners manual for this particular unit just to be certain?
Best regards
Ck
I need a new pot
call west bend customer service and they will be able to send you another i thought they glass lined
I need a new lid
You can try to call 866-290-1851
The only part they have for your pot is the crock...
http://www.westbend.com/finditem.cfm?itemid=3063
heatman101
I have the oval west
West Bend no longer carries the replacement lid. The only part that they carry for this model is the crock itself.
Your best bet is to keep an eye on eBay for the item. Often there are parts available. I have just looked using your model number, however, it could be the the lid is not marked, which makes the task a little harder. You can however scan through "oval crockpot lids" and see if you can find your lid. I have just looked that way also and do not see anything that would be your lid. another good source for this type of part is a secondhand store. Good luck! Thank you for using FixYa and please rate this answer.
