20 Most Recent
Zojirushi NP-HBC18 Rice Cooker Questions & Answers
How to replace battery in Zojirushi NP-HBC18 Rice Cooker?
Not that exact model, but I have replaced the battery in two others. The unit will likely have four screws in the bottom, possibly some snap-together hooks on the sides. The battery will be on the small circuit board under the display and buttons. It should be a CR2450 or similar sized 3V cell with two tabs soldered to the circuit board. My local battery store did not have exact replacements, but any 3V cell with the proper tab spacing will work. Make sure to note the polarity of the old cell prior to removing.
3/15/2015 8:33:30 PM •
Zojirushi...
Answered
on Mar 15, 2015
My rice cooker does not
I had this happen, and it turned out that the GFCI power outlet had tripped. You may want to try plugging something else in the outlet first and see if that item works - if that other item doesn't work, hit the reset button on your GFCI outlet, alternatively you may have to switch the breaker in your breaker box.
4/23/2013 4:30:58 AM •
Zojirushi...
Answered
on Apr 23, 2013
